Results 1 to 8 of 8
Thread: Lib AUDIO / dirty sound!?
    Oct 2014
    Paris
    13
    i don't understand why my code is doing a dirty sound!?
    #define  BAUDRATE         115200     // vitesse du port serie
    #define  SYNTH            4        // Synthesizers
    AudioSynthWaveform Waveform0, Waveform1, Waveform2, Waveform3;
    AudioEffectEnvelope Envelope0, Envelope1, Envelope2, Envelope3;
    AudioMixer4              mixer1;
    AudioOutputI2S           audioOut;
    AudioConnection          patchCord1(Waveform0, Envelope0);
    AudioConnection          patchCord2(Waveform1, Envelope1);
    AudioConnection          patchCord3(Waveform2, Envelope2);
    AudioConnection          patchCord4(Waveform3, Envelope3);
    AudioConnection          patchCord5(Envelope0, 0, mixer1, 0);
    AudioConnection          patchCord6(Envelope1, 0, mixer1, 1);
    AudioConnection          patchCord7(Envelope2, 0, mixer1, 2);
    AudioConnection          patchCord8(Envelope3, 0, mixer1, 3);
    AudioConnection          patchCord9(mixer1, 0, audioOut, 0);
    AudioConnection          patchCord10(mixer1, 0, audioOut, 1);
    AudioControlSGTL5000     audioShield;
    typedef struct synth {
      boolean state;        // true:free - false:buisy
      byte sensorID;        // 1 to 64 (8_8 matrix)
      int metro;
      int timeON;
      unsigned long lastPlayTime;
      AudioSynthWaveform *Waveform;
      AudioEffectEnvelope *Envelope;
      synth allSynth[SYNTH] = {
     { false, -1, 2000, 100, 0, &Waveform0, &Envelope0 },
     { true, -1, 2000, 100, 0, &Waveform1, &Envelope1 },
     { true, -1, 2000, 100, 0, &Waveform2, &Envelope2 },
     { true, -1, 2000, 100, 0, &Waveform3, &Envelope3 },
    int synthIndex = 0;
    /////////////////////// INITIALISATION
    void setup(){
      // Serial.begin(BAUDRATE);    // initialize serial
      //  analogReadRes(16);
      //  analogReadRes(12);
      // Setup Teensy audio shield
      AudioMemory(18);
      audioShield.enable();
      audioShield.volume(0.45);
      mixer1.gain(1, 0.8);
      mixer1.gain(2, 0.8);
      mixer1.gain(3, 0.8);
      mixer1.gain(4, 0.8);
      // Init all synthetizers
      for( int i=0; i<SYNTH; i++ ) {
        allSynth[i].Waveform -> pulseWidth( 0.5 );
        allSynth[i].Waveform -> begin( 0.5, 440, WAVEFORM_SINE );
        allSynth[i].Envelope -> attack( 5 );
        allSynth[i].Envelope -> decay( 100 );
        allSynth[i].Envelope -> release( 200 );
    /////////////////////// BOUCLE PRINCIPALE
    void loop(){
        if( allSynth[synthIndex].state == false ){  // false == BUSY_SYNTH
          if( ( millis() - allSynth[synthIndex].lastPlayTime ) >= allSynth[synthIndex].metro ){
            allSynth[synthIndex].Envelope -> noteOn();
          if( ( millis() - allSynth[synthIndex].lastPlayTime ) >= ( allSynth[synthIndex].metro + allSynth[synthIndex].timeON ) ){
            allSynth[synthIndex].Envelope -> noteOff();
            allSynth[synthIndex].lastPlayTime = millis();
      synthIndex++;
      synthIndex = synthIndex % SYNTH;
    23,974
    You're the same at this, right?
    https://github.com/PaulStoffregen/Audio/issues/91
    Before I start digging into this, could you try setting all the mixer channels to 0.25, and test again, for the sake of eliminating clipping in the mixer as a possible problem.
    In other words, change this:
    to this:
      mixer1.gain(1, 0.25);
      mixer1.gain(2, 0.25);
      mixer1.gain(3, 0.25);
      mixer1.gain(4, 0.25);
    23,974
    Or better yet, change it to this:
      mixer1.gain(0, 0.25);
    The mixer channels are numbered 0 to 3, so the last line had no effect and the first channel was still defaulting to 1.0.
    Detailed documentation on the mixer is available here:
    http://www.pjrc.com/teensy/gui/?info=AudioMixer4
    Oct 2014
    Paris
    13
    Yes i'm the one who post on the git sorry for that.
    I changed the audio mixer as you said but I still have a dirty sound.
    23,974
    Can you post the exact code you're running right now? I'll give it a try here, probably early tomorrow.
    Oct 2014
    Paris
    13
    AudioSynthWaveform waveform0, waveform1, waveform2, waveform3;
    AudioEffectEnvelope envelope0, envelope1, envelope2, envelope3;
    AudioMixer4              mixer1;
    AudioConnection          patchCord1(waveform0, envelope0);
    AudioConnection          patchCord2(waveform1, envelope1);
    AudioConnection          patchCord3(waveform2, envelope2);
    AudioConnection          patchCord4(waveform3, envelope3);
    AudioConnection          patchCord5(envelope0, 0, mixer1, 0);
    AudioConnection          patchCord6(envelope1, 0, mixer1, 1);
    AudioConnection          patchCord7(envelope2, 0, mixer1, 2);
    AudioConnection          patchCord8(envelope3, 0, mixer1, 3);
      int metro;
      int timeON;
     { true, -1, 2000, 300, 0, &waveform0, &envelope0 },
     { true, -1, 2000, 300, 0, &waveform1, &envelope1 },
     { true, -1, 2000, 300, 0, &waveform2, &envelope2 },
     { false, -1, 2000, 300, 0, &waveform3, &envelope3 },
    int synthIndex = 0;
    void setup(){
      AudioMemory(8);
      audioShield.volume(0.7);
        allSynth[i].Waveform -> begin( 0.1, 440, WAVEFORM_SINE );
        allSynth[i].Envelope -> attack( 50 );
        allSynth[i].Envelope -> decay( 50 );
        allSynth[i].Envelope -> release( 250 );
    void loop(){
      synthIndex++;
    Oct 2014
    Paris
    13
    Ok i found the bug In the logic level
    I was sending to many noteON();
    I added a boolean to solve the problem.
    23,974
    Try running this and view the output in the serial monitor.
    AudioMixer4              mixer1;
      int metro;
      int timeON;
    int synthIndex = 0;
    void setup(){
      AudioMemory(8);
    void loop(){
        if ( allSynth[synthIndex].state == false ) {  // false == BUSY_SYNTH
          if( ( millis() - allSynth[synthIndex].lastPlayTime ) >= allSynth[synthIndex].metro ) {
            Serial.print(synthIndex);
            Serial.println(" on");
            Serial.println(" off");
      synthIndex++;
    Your code appears to be rapidly restarting the waveform. I don't understand what this is supposed to do, but I'm pretty sure it should not print hundreds of "on" for each "off", right?
    I don't know what this code is supposed to do, and I'm not quite following your logic, but hopefully this helps you find a path to resolving the problem?
