We will have 2 Teensy's in our installation controlling 1500-3000 leds (density to be determined). The 2 Teensy's will be running different user code and will run independently of each other. The installation will be supported remotely, the reset button unreachable and code will be updated from time to time to change the experience. We need to have a reliable way to run HalfKay and load new user code.
I see on this page:
https://www.pjrc.com/teensy/loader_cli.html
It mentions using a second Teensy to reboot the 1st Teensy. So our setup would look like:
Control Server 1
Server 1 USB to LED Teensy 1
Server 1 USB to Reboot Teensy 1
LED Teensy 1 connected from Reset to Reboot Teensy 1 Pin C7
Control Server 2
Server 2 USB to LED Teensy 2
Server 2 USB to Reboot Teensy 2
LED Teensy 2 connected from Reset to Reboot Teensy 2 Pin C7
Do you see any issues with this setup?
It appears that we cannot have all 4 Teensy controlled from the same server if we use the command line, is that correct?
Is the CLI compatible with 3.1? The CLI page did not list the option for the mk20dx256
Thank you for your help.
-Ron
I see on this page:
Control Server 1
Control Server 2
-Ron
