onehorse
I want to use an array (>=2) of MEMS digital microphones like these to try out "echo location" using frequencies near the Helmholtz resonant 18 KHz. The circuit diagram shows the L/R input going to a CODEC. Most of the CODEC chips I have looked at are gigantic and support hi-fi audio output. That's overkill for me. I just want to take the signal(s) and do some FFT operations on them looking for differential doppler shifts to get a bearing. So some questions:
1) Is there some easier, smaller decoding I can do with the Teensy 3.x by itself or in concert with a small smd chip, and
2) What is the best way to generate an 18 kHz narrow band signal? Can I just use the same MEMS microphone as a "speaker", i.e., sound generator?
I am looking for very small form factor solutions.
This is all new to me so any suggestions are welcome!
