Results 1 to 2 of 2
Thread: Teensy 3.1 Pulse sensor port
    Dec 2014
    2
    I am currently trying to get the SparkFun Pulse sensor module to work with a teensy 3.1.
    I am currently just trying to get the demo code working to use as a basis for further development,
    The problem I am having is although the code compiles and load onto the board when run the sketch does not appear to be reading from the analogue input, with an value of 0 being output for raw sensor output over the serial port.
    When i run the analogue example sketch for the same pin the raw sensor data is reported correctly.
    Source code attached,
    (edit) - used analogue read to probe input pin directly - sensor value is displayed correctly, but var signal is still staying 0 .
    any help greatly appreciated.
    Fraser
    Attached Files Attached Files
    Dec 2014
    2
    Can anyone see where im going wrong?
