Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: A little competition :-)
    Germany NRW
    6,919
    A little competition:
    You can win nothing but glory, honor, and your mention in the source code.
    /* From coder.h, ORIGINAL:
     do y <<= n, clipping to range [-2^30, 2^30 - 1] (i.e. output has one guard bit)
    #define CLIP_2N_SHIFT(y, n) {                   \
            int sign = (y) >> 31;                   \
            if (sign != (y) >> (30 - (n)))  {       \
                (y) = sign ^ (0x3fffffff);          \
            } else {                                \
                (y) = (y) << (n);                   \
    Wanted is a terribly fast(er) implementation of this macro:
    The rules:
    a) Understand the macro.
    b) Assembler is expressly permitted, but not a must. If c-code is used: Use GCC 4.8.4
    c) Prove that your solution is faster. And correct.
    d) There may be no quicker solution. That is bad luck.
    e) It is fun to you.
    Explanation: This macro is used in the Helix codecs (compressed audio). Not very often. But I do not like it. :-)
    Edit : it's for Teensy 3. y is signed int (32 Bit), n too, but only positive values for n. We use GCC 4.8.4.
    n is NOT compile-time constant.
    22,272
    Is "n" a variable or compile-time constant?
    Germany NRW
    6,919
    n is a variable and not constant.
    hey it should'nt be too easy :-)
    3,764
    Be sure to label your code as for ARM only (int is 16-its on AVR platforms), or perhaps change the int's to int32_t or long. Obviously if people write in ASM, it will tie you to the ARM 32-bit architecture.
    Also, on some platforms, signed shift right might not sign extend, but those systems may be fairly rare these days. I wrote a C front end for a machine (long since RIP) that did not do arithmetic shifts, and the ISO C standard explicitly says that it is implementation defined. Most implementations support arithmetic shifts, but you are not guaranteed about this.
    Germany NRW
    6,919
    Ok, it's for Teensy 3. y is signed int (32 Bit), n too, but only positive values for n. We use GCC 4.8.4.
    22,272
    Well, I just tried ARM's SSAT instruction, and I can confirm it does not work.
    ARM's documentation isn't clear (at least to me) about how it saturates. But a little testing shows the shift is done first without saturation, and then the result is saturated.
    Germany NRW
    6,919
    Yes, i tried SSAT too, with no luck. OK: i'm willing to accept SSAT - if, at the end of the day - it sounds (the sound-output .. uh..my english is not good enough) )equal or better. Maybe this is the case ?
    There is an other Macro "CLIPTOSHORT", and i used SSAT there. It did not make any difference.
    Edit: i'm NOT a thumb-assembler-expert.
    22,272
    What values are actually used for "n" ?
    If it's only a few cases, perhaps each can be optimized?
    Germany NRW
    6,919
    It's midnight here.. i have to go to work tomorrow...so please understand, that i can't answer more questions now :-)
    Germany NRW
    6,919
    Whoops , to be honest : I do not know.
    2,698
    Not, that I can contribute to this optimization, but I find interesting, what the complier does
        int sign = (y)>>31;         \
        if(sign != (y)>>(30-(n))){  \
            (y)=sign ^ 0x3fffffff;  \
        } else {                    \
            (y)=(y)<<(n);           \
    int F1(int y, int n)
    { 	CLIP_2N_SHIFT(y,n);
    	return y;
    becomes (in principle)
      15              		.text
      16              		.align	2
      17              		.global	F1
      18              		.thumb
      19              		.thumb_func
      20              		.type	F1, %function
      21              	F1:
      22              		@ args = 0, pretend = 0, frame = 0
      23              		@ frame_needed = 0, uses_anonymous_args = 0
      24              		@ link register save eliminated.
      25 0000 C1F11E02 		rsb	r2, r1, #30
      26 0004 40FA02F2 		asr	r2, r0, r2
      27 0008 C317     		asrs	r3, r0, #31
      28 000a 9A42     		cmp	r2, r3
      29 000c 1ABF     		itte	ne
      30 000e 83F04040 		eorne	r0, r3, #-1073741824
      31 0012 C043     		mvnne	r0, r0
      32 0014 8840     		lsleq	r0, r0, r1
      33 0016 7047     		bx	lr
      34              		.size	F1, .-F1
      35              		.ident	"GCC: (GNU Tools for ARM Embedded Processors) 4.8.4 20140725 (release) [ARM/embedded-4_8-br
    It is always instructive to see what assembler will do with your code.
    2,698
    It seems that the following macro is about 6% faster
    #define CLIP_2N_SHIFT2(y, n) {            \
    	(y) = (y)<<(n);	                  \
    	if((y)>  1<<30 -1) (y) =  1<<30-1;\
    	if((y)< -1<<30)    (y) = -1<<30;  \
    Also, the numbers of instructions are fewer.
    Germany NRW
    6,919
    	(y) = (y)<<(n);	                  \
    Further proof that simple code also is better: -)
    	lsls	r0, r0, r1
    	cmp	r0, #536870912
    	bgt	.L7
    	cmp	r0, #-1073741824
    	it	lt
    	movlt	r0, #-1073741824
    	bx	lr
    .L7:
    	mov	r0, #536870912
    	bx	lr
    Btw, GCC 4.9 produces the same output.
    Seattle, WA
    12
    You forgot that the original code correctly saturates when the left-shift overflows. It's the same problem that Paul describes above with __SSAT(y<<n, 31). Bits are lost during the shift before saturation takes place.
    Here is an alternate method:
    int CLIP_2N_SHIFT(int x, int n)
    	int y = __SSAT(x << n, 31);
    	if (x != y >> n)
    		y = 0x3fffffff ^ (x >> 31);
    	return y;
    that can be implemented in two less instructions than the original, if the constant is hoisted outside the loop:
    // outside the loop
            MVN      r12,#0xc0000000
    // r2 = CLIP_2N_SHIFT(r0, r1)
            LSL      r2,r0,r1
            SSAT     r2,#31,r2
            ASR      r1,r2,r1
            CMP      r1,r0
            IT       NE
            EORNE    r2,r12,r0,ASR #31
    Germany NRW
    6,919
    Thanks sublinear,
    i don't think that the constant can moved outside.
    But one cycle less is one cycle less ( Again , it 's not worth it to really optimize it, but it's a brain teaser :- )
    There is a similar macro, which is used more often, without shift:
    //clip to [-2^n, 2^n-1], valid range of n = [1, 30]
    #define CLIP_2N(y, n) { \
    	if (sign != (y) >> (n))  { \
    		(y) = sign ^ ((1 << (n)) - 1); \
    2,698
    Nevertheless, it was a nice exercise and I refreshed my (limited) Assembler skills.
    Also concerning optimization, here a bit, there a bit, could result in something useful.
    BTW: Anyone knows how to program in C, or tell the compiler the following:
            IT       NE
    Germany NRW
    6,919
    I agree.
    My Assembler skills are 20..25 years old (z80, 6502)..since then..nothing. The only ARM on the market was the ACORN., i think....
            IT       NE
    AFAIK: IT is "IF-THEN", make the next instruction(s) conditional.It is not a "real" instruction and does not need space.
    EOR NE is then the conditional instruction, only executed when NE flag is set ( i can be wrong )
    So.. i think there is no direct translation to c.
    EOR is ^ in C
    In pseudocode: if last operation was (edit: NOT) "eqal" then r2 = r12 ^ (r0 << 31) (i hope this is correct ?!)
    2,698
    @Frank
    Is the following not what you wanted (here only for bit 9 and with positive and negative numbers), or do I miss something?
    int nn;
      int ii,jj,nn;
      char text[80];
      int yy1,yy2;
      while(1)
      {  delay(1000);
        nn=2;
        for(ii=0; ii<100;ii+=5)
          asm volatile("ssat %0, %1, %2" : "=r" (yy1) : "I" (9), "r" (-ii<<nn));
          asm volatile("ssat %0, %1, %2" : "=r" (yy2) : "I" (9), "r" (ii<<nn));
          sprintf(text,"%d %d %x %d %x",ii,yy1,yy1,yy2,yy2);
          Serial.println(text);
    which results to
    5 -20 ffffffec 20 14
    10 -40 ffffffd8 40 28
    15 -60 ffffffc4 60 3c
    20 -80 ffffffb0 80 50
    25 -100 ffffff9c 100 64
    30 -120 ffffff88 120 78
    35 -140 ffffff74 140 8c
    40 -160 ffffff60 160 a0
    45 -180 ffffff4c 180 b4
    50 -200 ffffff38 200 c8
    55 -220 ffffff24 220 dc
    60 -240 ffffff10 240 f0
    65 -256 ffffff00 255 ff
    70 -256 ffffff00 255 ff
    75 -256 ffffff00 255 ff
    80 -256 ffffff00 255 ff
    85 -256 ffffff00 255 ff
    90 -256 ffffff00 255 ff
    95 -256 ffffff00 255 ff
    It seems to me, that there is no need to check on negative numbers, or am I wrong?
    The assembler has only two lines (apart from moving data to and from registers)
      60 0024 04FA02F2 		lsl	r2, r4, r2
      61              	@ 110 "src/main.c" 1
      62 0028 02F30802 		ssat r2, #9, r2
      63              	@ 0 "" 2
      64              		.thumb
    Germany NRW
    6,919
    almost..but now replace #9 with 2n
    2,698
    Is my #9 (limiting to +255/-256) not equivalent to your (2^30-1/ -2^30) of post #1?
    The left shift is, because not constant, anyway outside ssat.
    Germany NRW
    6,919
    int nn;
            } else {                                \
                (y) = (y) << (n);                   \
      int ii,nn;
      int yy1,yy2;
      while(1)
        nn=0;
        for(ii=((1<<30)-5); ii<((1<<30)+5);ii++)
          asm volatile("ssat %0, %1, %2" : "=r" (yy1) : "I" (30), "r" (-ii<<nn));
          asm volatile("ssat %0, %1, %2" : "=r" (yy2) : "I" (30), "r" (ii<<nn));
          int z1 = ii;
          CLIP_2N_SHIFT(z1,nn);
          int z2 = -ii;
          CLIP_2N_SHIFT(z2,nn);
          Serial.printf("%x: %d %x %d %x   !=    %x %x\r\n",ii,yy1,yy1,yy2,yy2, z1, z2);
    hmm...
    2,698
    [code]
    hmm...
    but replace by 30 by 31 (one bit above the maximum number, in my previous case 9 for -256 to 255 (256 =2^8, right?)
    as in
    int nn;
            } else {                                \
                (y) = (y) << (n);                   \
      int ii,nn;
      int yy1,yy2;
      while(1)
        nn=0;
          asm volatile("ssat %0, %1, %2" : "=r" (yy1) : "I" (31), "r" (-ii<<nn));
          asm volatile("ssat %0, %1, %2" : "=r" (yy2) : "I" (31), "r" (ii<<nn));
          int z1 = -ii;
          int z2 = ii;
          Serial.printf("%x: %x %x   ==    %x %x\r\n",ii,yy1,yy2, z1, z2);
    na also
    Germany NRW
    6,919
    as in
    int nn;
            } else {                                \
                (y) = (y) << (n);                   \
      int ii,nn;
      int yy1,yy2;
      while(1)
        nn=0;
          int z1 = -ii;
          int z2 = ii;
    na also
    Ok.. hast du nn=1 versucht ?
    2,698
    OK, one has to test also if shift overflows the 32 bit boundary. So it comes back to sublinear's solution.
    22,272
    Does this need to support all 31 possible values of "n"? Or are only certain, compile-time constant values used?
    If only 2 or 3 values are ever used for n, and they're constants, maybe each case could be optimized separately?
