Results 1 to 3 of 3
Thread: Teensy Internal file system
    Dec 2014
    2
    Hi ,
    I am trying to understand the process of building internal FAT12 file system on the teensy2 (internal FS not on SD).
    I see that there is some kind of a utility which is called mktinyfat.
    1. Is there a source code or any documentation to this utility ?
    2. Is there a way to change label of volume for internal disk ?
    thanks ,
    E.H.
    25,067
    No, there's no source and no documentation.
    But, if you haven't provided any files to populate the filesystem, it does put a readme file into the empty filesystem. That readme file has instructions regarding how you can set the volume label.
    Dec 2014
    2
    probably MY BAD , I saw the file and read it before... probably missed it somehow...
    Thanks a lot for your quick reply !
