uint32_t AudioPlaySdWav::positionBytes(void) // keep track of the current position
bool AudioPlaySdWav::seek(const char *filename, uint32_t pos) // resume from position pos
Have had a look at it, and its probably a bit above my skills to fix at the moment
what kind of audio?
i assume you mean pause as in pause/resume a .wav file? or stop things in general?
if the former, you'd need to add some simple functions to the respective class.
for instance, or that's one way (re: PlaySdWav):*
Code:uint32_t AudioPlaySdWav::positionBytes(void) // keep track of the current position
Code:bool AudioPlaySdWav::seek(const char *filename, uint32_t pos) // resume from position pos
if the latter, someone else would have to chime in, it's not something I felt i needed so far. there's "AudioNoInterrupts" which "allows you to briefly suspend the audio library"; but I'm not sure what "briefly" means in this context. (ie whether it implies suspend "indefinitely").
* more detail here
byte_offset = (1+pos)<<9;
stop();
__disable_irq();
AudioStartUsingSPI();
wavfile = SD.open(filename);
__enable_irq();
if (!wavfile) {
AudioStopUsingSPI();
return false;
buffer_length = 0;
buffer_offset = 0;
state_play = STATE_STOP;
data_length = 20;
header_offset = 0;
playseek = true;
state = STATE_PARSE1;
return true;
#ifndef play_sd_raw_h_
#define play_sd_raw_h_
#include "AudioStream.h"
#include "SD.h"
class AudioPlaySdRaw : public AudioStream
public:
AudioPlaySdRaw(void) : AudioStream(0, NULL) { begin(); }
void begin(void);
bool play(const char *filename);
void pause(bool pst);/////////////////////// PAUSE TEST
bool seek(const char *filename, uint32_t pos);
void stop(void);
bool isPlaying(void) { return playing; }
uint32_t positionMillis(void);
uint32_t positionBytes(void);
uint32_t lengthMillis(void);
uint32_t lengthBytes(void);
virtual void update(void);
private:
File rawfile;
uint32_t file_size;
volatile uint32_t file_offset;
volatile bool playing;
volatile bool attend = false; /////////////////////////PAUSE TEST
uint32_t byte_offset;
void AudioPlaySdRaw::update(void)
unsigned int i, n;
audio_block_t *block;
// only update if we're playing
if (!playing) return;
// allocate the audio blocks to transmit
block = allocate();
if (block == NULL) return;
if (rawfile.available()) {
// we can read more data from the file...
if (attend == false){n = rawfile.read(block->data, AUDIO_BLOCK_SAMPLES*2);}////////////////PAUSE TEST
file_offset += n;
for (i=n/2; i < AUDIO_BLOCK_SAMPLES; i++) {
block->data[i] = 0;
transmit(block);
rawfile.close();
playing = false;
release(block);
void AudioPlaySdRaw::pause(bool pst){ ////////////////PAUSE TEST
attend = pst;
if (button0.fallingEdge()) {
//freeze = 1;
//pos = playSdRaw.positionMillis();
float ax = sq(AcX/4+4000);
//Serial.println(ax);
float msec = ax/100000.0;
msec = constrain(msec, 10, 550);
granular.beginFreeze(msec); //msec
Serial.print("Begin granular freeze using ");
Serial.print(msec);
Serial.println(" grains");
delay(msec);
playSdRaw.pause(true);
if (button0.risingEdge()) {
granular.stop();
//freeze = 0;
playSdRaw.pause(false);
