Ben
Hello everyone, a quick question:
I'd like to use Teensy 3.0 with an SPI-flash at high bus speed. The default pin for SPI clock is Pin 13, which has the Teensy onboard LED attached to it. May this LED pose a capacitive load big enough to degrade the clock signal at high speeds, or am I worrying without any reason?
I'd not bother to ask and just use the alternate clock cin (Pin 14 / A0), but that would substantially complicate my PCB layout, plus I'd loose one analog input and had to start using the SMT-pads on the bottom (A12 and A13).
Ben
Ben
