I am trying Teensy 3.1 with the WIZ820io & Micro SD Card Adaptor, the WIZnet WIZ820io and the OctoWS2811 Adaptor.
Soldered together in a board stack, OctoWS2811 adapter on the bottom, then Teensy 3.1 then the WIZ820io adaptor and the WIZ820io on top. Teensy is powered through the +5V and GND pins on the OctoWS2811 adapter and the VIN and VUSB pads on the Teensy are cut apart. The power supply is providing 5.19 V measured at the pins on the OctoWS2811 adapter and it is rated for 100W or 20A. I power a LED strip from the same supply as well, the total draw of the strip should be 65 W when all of them are on on full intensity, which during the testing they never were because it's way too bright.
I have installed Arduino 1.0.6 and Teensyduino 1.20.
First noticed a problem with the example sketch called "ArtNet", included with the OctoWS2811 library. It would hang after 24 hours or so, sometimes shorter sometimes longer. I realized after some testing that it appears that the Teensy is not hung but the WizNet is, at least that's how I interpret not being able to ping the WIZ820io, but being able to reload the sketch and reboot Teensy without removing the power from it. The same problem happens on two separate but identical Teensy hardware setups.
I came across some problem reports with WIZ820io and WebServer, so I loaded the WebServer example from the Ethernet library and crashed it in short order by reloading the page several times with the F5 button on my PC. (Note that no LEDs were on during this test, so all the 20A power was available to Teesy.) The crash looked similar as the crash with "ArtNet" which took a long time to happen. It does not respond to ping, but reloading the sketch works.
Now I'm convinced that the problem is with the WIZ820io or the library that I'm using with it but I don't know how to solve it. Please help.
