Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 92 of 92
Thread: Teensyduino 1.21 Test #2 Available
  1. #76
    20,576
    Quote Originally Posted by Codefella View Post
    let me know if i could provide further information.
    Please try with Arduino 1.6.0 and Teensyduino 1.21-beta5.
    https://forum.pjrc.com/threads/27740...ll=1#post64839
    Arduino 1.6.0 switched to an entirely new serial library. Odds are good that will solve the problem. If not, I'd like to only pour dev work into the new JSSC library path. The old RXTX library is a dead end.
  2. #77
    Feb 2014
    Colmar, France
    2,532
    Arduino 1.6.0 and Teensyduino 1.21-beta5 work fine for me. There was still an old annoying issue which would ask me every time when I open the Arduino app if I wanted to allow incoming connections. That's an OS X problem because the original (signed) Arduino.app was modified by Teensyduino. Resigning Arduino.app with a self generated key after installing Teensyduino did the trick and the annoying dialog disappeared.
  3. #78
    Feb 2014
    Bavaria
    13
    Still the same problem. problem also appears if opening the "Tools" menu in the arduino IDE. must be some kind of delay when checking installed com ports.
    but there's no lag when opening the serial monitor with old teensyduino version.
    i think you could reproduce the problem by installing the following driver which emulates an com port for an rs232/ethernet adapter: http://www.wut.de/download/e-00111-ww-swww-420.exe
  4. #79
    Dec 2014
    4
    The installer still shows that it is for Arduino ver. 1.0.5 and 1.0.6. Just a reminder to update.
  5. #80
    Did the pin33 low on boot issue get addressed in this one? https://forum.pjrc.com/threads/24823...ighlight=pin33
  6. #81
    Oct 2012
    Portland OR
    676
    many retries needed with Win7, 1.21-beta6
    I seem to get a lot of retries when programming Teensy 3 from Win7 with Arduino 1.0.6 / Teensyduino 1.21-beta6 before the programming finally completes. A few times it has stopped midway with an error, but re-trying then succeeds.
    teensy_reboot, verbose mode
    Device Instance: 2048
      DeviceRegistryProperty: acquired
      Key type: REG_MULTI_SZ
        property: USB\VID_16C0&PID_0483&REV_0100
      Registry Key: acquired
      PortName: "COM23"
      pathname: \\.\COM23
    add_serial_name, \\.\COM23
    trying port 3149
    found Teensy Loader, version 1.21
    send: status - at Sat Feb 28 09:35:52 2015
    do_reset (serial) \\.\COM23
    status read, retry 0
    status read, retry 1
    status read, retry 2
    send: status - at Sat Feb 28 09:35:53 2015
    status read, retry 3
    status read, retry 4
    status read, retry 5
    status read, retry 6
    Success
  7. #82
    136
    @PaulStoffregen
    Unfortunately, the installer of Teensyduino 1.21 Test #2 doesn't detect Arduino 1.6.0 on Mac OS X.
  8. #83
    20,576
    Delete that old "-test2" copy. Five more have been published since them. Get the latest, which works great with Arduino 1.6.0:
    https://forum.pjrc.com/threads/27740...ll=1#post66275
  9. #84
    136
    Thank you!
  10. #85
    5
    I am having this issue too. sprintf stopped working with the 1.21 test#2. Any way to fix?
    Thanks, Chip
  11. #86
    1,155
    sprintf of float and double now work with beta8 and 1.6.0 on a Teensy 3.1 (see the test code in #14) but neither of them work on T3.0 or T-LC
    Pete
  12. #87
    20,576
    Look in Tools > CPU Speed. 1.21-beta8 has new choices, to optimize for speed or code size.
    The small code size settings default to a printf and scanf without floating point. But there's a trick to get the float versions:
    https://forum.pjrc.com/threads/27827...-on-Teensy-3-1
  13. #88
    1,155
    That fixed it! Thanks Paul.
    Pete
  14. #89
    Jun 2013
    So. Calif
    2,828
    can the IDE have a GUI to enable big printf, along with compiler optimization choices?
  15. #90
    I just installed Arduino 1.6.1 and downloaded teensy 1.21-beta8.
    But when I try to install I get a popup with supported arduino Versions and there is this error
    Directory: C:/Program Files (x86)/Arduino/
      Checking Arduino 1.0.5:
        file: "arduino.exe"  present
        file: "rxtxSerial.dll"  missing
        Does not match Arduino 1.0.5
      Checking Arduino 1.0.6:
        Does not match Arduino 1.0.6
      Checking Arduino 1.6.0:
        file: "arduino_debug.exe"  present
        file: "lib/jssc-2.8.0.jar"  present
        file: "hardware/arduino/avr/boards.txt"  present
        file: "hardware/arduino/avr/platform.txt"  present
        dir: "hardware/arduino/avr/cores/arduino"  present
        file: "hardware/arduino/sam/boards.txt"  present
        file: "hardware/arduino/sam/platform.txt"  present
        dir: "hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1"  present
        dir: "libraries"  present
        dir: "examples"  present
        java: "lib/pde.jar" object: "processing/app/Base.class" wrong size, unsupported Arduino version
        Does not match Arduino 1.6.0
      Checking Arduino 1.6.1:
        Does not match Arduino 1.6.1
    I'm Using Windows 8.1 X64
  16. #91
    20,576
    How'd you download beta8? I left the files on the server, but removed the all links. Or at least I thought I removed all the old links.
    We're on beta10 now, and there's a known issue where it's only recognizing the Windows ZIP file for 1.6.1, but not the EXE installer version. Tuesday's 1.6.1 release was the first Arduino has ever published different files in the 2 Windows downloads! I'm working on a fix today.
    If you want to try now, use beta10 and the Windows ZIP file version.
  17. #92
    you were right it was the beta 10 and yes it gives the error.
    I wait for the fix on the exe file
