I thought I did provide all the details. If by providing the code used, no I didnt do that. As I am using the exact example located within the Arduino example code that comes with your libraries. But I will post it here. The files on the SD card are named in the following way.. 01SD.raw , 02SD.raw , etc... They are on a 4GB Kingston HC level 10 SD card. The card has been formatted several times to erase and start fresh. Any other details you need, please let me know. Thank you.
const int SDchipSelect = 10; // Audio Shield has SD card CS on pin 10
const int FlashChipSelect = 6;
//uncomment these if using Teensy audio shield
SPI.setSCK(14); // Audio shield has SCK on pin 14
SPI.setMOSI(7); // Audio shield has MOSI on pin 7
// wait up to 10 seconds for Arduino Serial Monitor
unsigned long startMillis = millis();
while (!Serial && (millis() - startMillis < 10000)) ;
Serial.println("Copy all files from SD Card to SPI Flash");
if (!SD.begin(SDchipSelect)) {
error("Unable to access SD card");
if (!SerialFlash.begin()) {
error("Unable to access SPI Flash chip");
int count = 0;
File rootdir = SD.open("/");
while (1) {
// open a file from the SD card
File f = rootdir.openNextFile();
if (!f) break;
const char *filename = f.name();
Serial.print(filename);
Serial.print(" ");
unsigned long length = f.size();
Serial.println(length);
// check if this file is already on the Flash chip
if (SerialFlash.exists(filename)) {
Serial.println(" already exists on the Flash chip");
SerialFlashFile ff = SerialFlash.open(filename);
if (ff && ff.size() == f.size()) {
Serial.println(" size is the same, comparing data...");
if (compareFiles(f, ff) == true) {
Serial.println(" files are identical :)");
f.close();
ff.close();
continue; // advance to next file
Serial.println(" files are different");
Serial.print(" size is different, ");
Serial.print(ff.size());
Serial.println(" bytes");
// delete the copy on the Flash chip, if different
Serial.println(" delete file from Flash chip");
SerialFlash.remove(filename);
// create the file on the Flash chip and copy data
if (SerialFlash.create(filename, length)) {
if (ff) {
Serial.print(" copying");
// copy data loop
unsigned long count = 0;
unsigned char dotcount = 9;
while (count < length) {
char buf[256];
unsigned int n;
n = f.read(buf, 256);
ff.write(buf, n);
count = count + n;
Serial.print(".");
if (++dotcount > 100) {
dotcount = 0;
ff.close();
if (dotcount > 0) Serial.println();
Serial.println(" error opening freshly created file!");
Serial.println(" unable to create file");
f.close();
rootdir.close();
delay(10);
Serial.println("Finished All Files");
bool compareFiles(File &file, SerialFlashFile &ffile) {
file.seek(0);
ffile.seek(0);
unsigned long count = file.size();
while (count > 0) {
char buf1[128], buf2[128];
unsigned long n = count;
if (n > 128) n = 128;
file.read(buf1, n);
ffile.read(buf2, n);
if (memcmp(buf1, buf2, n) != 0) return false; // differ
count = count - n;
return true; // all data identical
void error(const char *message) {
while (1) {
Serial.println(message);
delay(2500);
