PaulStoffregen
In this example, the WAV file was already 44100 Hz sample rate. If it had been something else, an additional step in Audacity would have been needed to convert to 44100 Hz. Click the Tracks > Resample menu, and select 44100. This can be done before or after conversion from stereo to mono, but obviously it has to be 44100 Hz before you export to raw format.
If you convert from a higher to lower sample rate, make sure you play it in Audacity (click the green triangle button in the toolbar) to verify the conversion worked properly.
