Constantin
I read over at Adafruit about the space requirements for various variables, including booleans. It appears that on the AVR platform, they always consume a byte of memory. (And here I thought that booleans take up less space and hence used them as much as I could)
Are booleans treated similarly re SRAM needs on the Teensy 3? Does the answer change if you were to use an array of them?
Also, since the Teensy 3 lacks a dedicated FPU, I have tried to use integer math as much as possible. But floating points do creep in here and there... So I also want to confirm that the Teensy 3 double is in fact differentiated from a float, unlike on the Arduino platform?
