ChronopiumSilvestris
Hi wise helping people,
I'm building a fretless tapping instrument that has twelve independent strings and I'd like to turn it into a hybrid synth where the twelve inputs would be processed in SuperCollider with an Odroid (or something alike) and then fed back to the strings via independent speakers (or inductors). It sounded beautiful in a one string test, so in principle it should work.
The only problem is 12/16 channel soundcards are generally fancy and expensive, so I was hoping I could diy something with smaller components.
ADC's an DAC's seem relatively inexpensive, my worries are in the multiplexing and sending/receiving serial for so many channels. With external ADC's reading the sound, would the teensy be fast enough to send 12 floats at 48kHz to the computer? Or even better, could all 24 values (12 in, 12 out) go in the same USB?
Thank you for reading.
