Results 1 to 5 of 5
Thread: Using envelope to control filter frequency
    Jan 2015
    New Zealand
    6
    Hi everyone, first post
    just started out with the audio library (received the board today) and I am unsure how to use a ADSR envelope to modulate the filter frequency instead of the waveform amplitude?
    1. how do I connect the envelope to the filter?
    2. do I leave the envelope input open?
    3. a short code example would probably get me underway
    many thanks in advance
    Jan
    18,369
    Perhaps something like this?
    Jan 2015
    New Zealand
    6
    brilliant. Didn't see the forest for the trees.
    I am really impressed with the teensy hardware, software and support, btw. Thanks for that!
    Oct 2017
    12
    Hi Paul,
    What tool is that you're using ? Is that Pure Data ?
    No version of Max or Reason looks like that, at least that I'm aware of.
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    996
    That's the audio design tool
    https://www.pjrc.com/teensy/gui/
    It generates code to handle signal routing for the audio library
