Hi
I've been using Teensy 3.1 for about a week now on my project and it has been great so far. I'm currently taking it to the next step and add a Labview interface. I managed to set up my Labview software to work with the Arduino and did a simple blinky test and it worked fine. I had to use the Labview for Arduino Interface library to get this working.
Now, I am trying to set up the Labview to work with the Teensy.
I followed the steps on this page : https://www.pjrc.com/teensy/languages.html
I assume this is the same as the aforementioned library that is tweaked to work with the Teensy.
I extracted the file from the .zip and opened LVIFA_Base.ino. With my Teensy 3.1 connected, i tried to upload the .ino code but received the following error:
I've been stuck here for some time and can't find any way around this.
Any advice?
Thanks in advanced.
This modified Arduino code allows Teensy to work with LabVIEW's Arduino library.
enabled in File > Preferences.
Arduino: 1.0.5-r2 (Windows 7), Board: "Teensy 3.1"
AFMotor.cpp:94: error: #error "This chip is not supported!"
AFMotor.cpp:108: error: #error "This chip is not supported!"
AFMotor.cpp:125: error: #error "This chip is not supported!"
AFMotor.cpp:140: error: #error "This chip is not supported!"
AFMotor.cpp:158: error: #error "This chip is not supported!"
AFMotor.cpp:172: error: #error "This chip is not supported!"
AFMotor.cpp:192: error: #error "This chip is not supported!"
AFMotor.cpp:206: error: #error "This chip is not supported!"
In file included from AFMotor.cpp:13:0:
AFMotor.h:121: error: 'CS01' was not declared in this scope
AFMotor.cpp: In constructor 'AF_Stepper::AF_Stepper(uint16_t, uint8_t)':
AFMotor.cpp:310: error: 'CS20' was not declared in this scope
Any advice?
Thanks in advanced.
