I am trying to get my GPs teensy add-on to work; first assembled board did not give the right power to the GPS module and I haven't got back to this project to fix it. But this will give you an idea of what is possible if I can just get the soldering right.
In fact, this board suffers from two design flaws; the antenna input should be on top and the antenna path should be 17 mils wide instead of the 30 mils in this design. This means I need to rotate the module by -90 degrees and design a better rf path to the antenna from the module. TBD
