vitormhenrique
Hi Guys,
How are you? Quick and basic question.
On my project I want the teensy to control both the direction and enabling / disabling the 74HC245 chip, So I connected one IO to the OE pin and another to the DIR pin. My question is, should I actually use pull down / up resistors on those connections instead of connecting directly to Teensy IO's?
I could not find any example / information on the datasheet, so that must be a dumb question
74HC245 datasheet: http://www.nxp.com/documents/data_sheet/74HC_HCT245.pdf
