Problem 1
I'm using Teensy 1.20, Arduino 1.0.6, on a W7 64bit machine with Audio library downloaded yesterday from PJRC
Yesterday I was playing with my Teensy3.1 & audio board. I compiled & loaded the PlaySynthMusic example & it worked nicely, however when I unplugged the Teensy USB cable & plugged it into another PC OR a USB PSU it wouldn't play. It will only play immediately after downloading to the Teensy. Unplugging & replugging to my 'host' PC causes the Teensy loader to run again (all by itself). This seems to happen with other programs too but I'd never noticed before.
I had a quick look at the code and can't see anything obvious to cause this, but I don't know what could. This brings me to:
Problem 2
I notice in the code:
//while (!Serial1) ; // wait for Arduino Serial Monitor
Is this commented out because it doesn't work? I've tried this in other programs & it doesn't work for me. I notice on Paul's site https://www.pjrc.com/teensy/td_download.html that there is a revision note for Version 1.13: 'Fix while(!Serial)' but it doesn't indicate what was fixed.
Can anyone confirm or provide advice?
Ian
Problem 2
Ian
