Results 1 to 3 of 3
Thread: Teensy Loader has stopped auto loading but reset works - Normal?
    Jan 2015
    6
    I have made a custom USB Device with the Teesy 3.1 and have it working. Teensy Loader no longer loads a new program unless I press the reset button on the Teensy. I would like to know if this is normal or if there is something that I should change in the code to allow Teensy Loader to load programs from the IDE? I also do not see debug messages in the IDE's Serial Monitor. I would like to restore these two things if possible.
    Another Question: I included the serial device as I thought it may have been necessary for Teensy Loader and/or serial debuging in the IDE. Is it needed for either function? If not, I can remove it. (Yes, I could give it a try but wanted to ask. I would also like to get the other things working before removing it.)
    Project
    Custom Game Pad for Raspberry Pi with
    - Joystick
    - 10 buttons
    - 2 Keyboard buttons to act as hotkeys for OS
    - Raw HID device to communicate battery level
    Software
    Teensy: Teensy 3.1
    Teensy Loader: 1.20
    OS: Windows 7 Ultimate SP 1 (64-bit)
    IDE: Arduino 1.0.6 w/ Teensyduino 1.20
    Hardware Setup
    Teensy 3.1 (1)
    Adafruit PSP 2-Axis Analog Thumb Joystick PRODUCT ID: 444 (1) connected to 3.3VDC, GND, and Analog Pins 0 & 1
    Adafruit Tactile Switch Buttons (6mm slim) x 20 pack PRODUCT ID: 1489 (12) connected between GND and digital pins 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, & 11
    LEDs (6) connected to GND & 150 ohm resistors with the resistors connected to digital pins 18, 19, 20, 21, 22, & 23
    Code
    Changes to the default configuration to create Pi Controller USB Device - Phase_03b-Final.zip
    Test Code
    /* Complete USB Joystick Example
     Teensy becomes a USB joystick with 16 or 32 buttons and 6 axis input
     You must select Joystick from the "Tools > USB Type" menu
     Pushbuttons should be connected between the digital pins and ground.
     Potentiometers should be connected to analog inputs 0 to 5.
    // Configure the number of buttons.  Be careful not
    // to use a pin for both a digital button and analog
    // axis.  The pullup resistor will interfere with
    // the analog voltage.
    // Incudes modifications from
    // https://github.com/adafruit/USBgamepad/blob/master/teensySNES_test2/teensySNES_test2.ino
      This test for the Pi Control is to check the hardware
     The USB Type must be set to "Pi Controller"
    // Joystick
    const int pinAnalogXInput = 0;
    const int pinAnalogYInput = 1;
    // Buttons
    const int pinBtnA = 0;
    const int pinBtnB = 1;
    const int pinBtnX = 2;
    const int pinBtnY = 3;
    const int pinBtnTrigLeft = 4;
    const int pinBtnTrigRight = 5;
    const int pinBtnBack = 6;
    const int pinBtnStart = 7;
    const int pinBtnMenu = 8;
    const int pinBtnCoin = 9;
    // Special buttons for scripts
    const int pinBtnPwr = 10;
    const int pinBtnBatteryLevel = 11;
    // LEDs
    const int pinLedPower = 23;
    const int pinLed0 = 22;
    const int pinLed1 = 21;
    const int pinLed2 = 20;
    const int pinLed3 = 19;
    const int pinLed4 = 18;
    //Variables for the states of the buttons
    byte buttons[] = {
      pinBtnA, pinBtnB, pinBtnX, pinBtnY,
      pinBtnTrigLeft, pinBtnTrigRight,
      pinBtnBack, pinBtnMenu, pinBtnCoin, pinBtnStart};
    //Variables for the states of the special buttons
    byte specialButtons[] = {
      pinBtnPwr, pinBtnBatteryLevel};
    //Variables for the LEDs
    byte leds[] = {
      pinLedPower, pinLed0, pinLed1, pinLed2, pinLed3, pinLed4};
    #define NUMBUTTONS sizeof(buttons)
    #define NUMSPECIALBUTTONS sizeof(specialButtons)
    #define NUMLEDS sizeof(leds)
    typedef void KeyFunction_t(uint8_t c);
    byte allButtons[NUMBUTTONS];
    byte prevButtons[NUMBUTTONS];
    byte specialButtonsPressed[NUMSPECIALBUTTONS];
    // RawHID packets are always 64 bytes
    byte buffer[64];
    elapsedMillis msUntilNextSend;
    unsigned int packetCount = 0;
      // you can print to the serial monitor while the joystick is active!
      // configure the joystick to manual send mode.  This gives precise
      // control over when the computer receives updates, but it does
      // require you to manually call Joystick.send_now().
      Gamepad.useManualSend(true);
      for (int i=0; i<NUMBUTTONS; i++) {
        pinMode(buttons[i], INPUT_PULLUP);
      for (int i=0; i<NUMSPECIALBUTTONS; i++) {
        pinMode(specialButtons[i], INPUT_PULLUP);
      for (int i=0; i<NUMLEDS; i++) {
        pinMode(leds[i], OUTPUT);
        digitalWrite(leds[i], LOW);
      // initialize control over the keyboard:
      Keyboard.begin();
      Serial.println("Begin Complete Joystick Test");
      processGamepad();
      processKeyboard();
      processHID();
      // a brief delay, so this runs "only" 200 times per second
      delay(50);
      blinkLED();
    unsigned long previousMillis = 0;        // will store last time LED was updated
    // the follow variables is a long because the time, measured in miliseconds,
    // will quickly become a bigger number than can be stored in an int.
    long interval = 1000;           // interval at which to blink (milliseconds)
    void blinkLED() {
      // here is where you'd put code that needs to be running all the time.
      // check to see if it's time to blink the LED; that is, if the
      // difference between the current time and last time you blinked
      // the LED is bigger than the interval at which you want to
      // blink the LED.
      unsigned long currentMillis = millis();
      if(currentMillis - previousMillis > interval) {
        // save the last time you blinked the LED
        previousMillis = currentMillis;
        // set the LED with the ledState of the variable:
        digitalWrite(pinLed4, !digitalRead(pinLed4));
    void processGamepad() {
      // read 2 analog inputs and use them for the joystick axis
      Gamepad.X(analogRead(pinAnalogXInput));
      Gamepad.Y(analogRead(pinAnalogYInput));
      // read digital pins and use them for the buttons
        if (digitalRead(buttons[i])) {
          // when a pin reads high, the button is not pressed
          // the pullup resistor creates the "on" signal
          allButtons[i] = 0;
        else {
          // when a pin reads low, the button is connecting to ground.
          allButtons[i] = 1;
        Gamepad.button(i + 1, allButtons[i]);
      // Because setup configured the Joystick manual send,
      // the computer does not see any of the changes yet.
      // This send_now() transmits everything all at once.
      Gamepad.send_now();
      // check to see if any button changed since last time
      boolean anyChange = false;
        if (allButtons[i] != prevButtons[i]) anyChange = true;
        prevButtons[i] = allButtons[i];
      // if any button changed, print them to the serial monitor
      if (anyChange) {
        Serial.print("Buttons: ");
          Serial.print(allButtons[i], DEC);
    void processHID() {
      int n;
      n = RawHID.recv(buffer, 0); // 0 timeout = do not wait
      if (n > 0) {
        // the computer sent a message.  Display the bits
        // of the first byte on pin 0 to 7.  Ignore the
        // other 63 bytes!
        Serial.print(F("Received packet, first byte: "));
        Serial.println((int)buffer[0]);
          int b = buffer[0] & (1 << i);
          digitalWrite(leds[i], b);
      // every 2 seconds, send a packet to the computer
      if (msUntilNextSend > 2000) {
        msUntilNextSend = msUntilNextSend - 2000;
        // first 2 bytes are a signature
        buffer[0] = 0xAB;
        buffer[1] = 0xCD;
        // next 24 bytes are analog measurements
        for (int i=0; i<12; i++) {
          int val = analogRead(i);
          buffer[i * 2 + 2] = highByte(val);
          buffer[i * 2 + 3] = lowByte(val);
        // fill the rest with zeros
        for (int i=26; i<62; i++) {
          buffer[i] = 0;
        // and put a count of packets sent at the end
        buffer[62] = highByte(packetCount);
        buffer[63] = lowByte(packetCount);
        // actually send the packet
        n = RawHID.send(buffer, 100);
        if (n > 0) {
          Serial.print(F("Transmit packet "));
          Serial.println(packetCount);
          packetCount = packetCount + 1;
          Serial.println(F("Unable to transmit packet"));
    void processKeyboard() {
      // run through all the special buttons
      for (byte i = 0; i < NUMSPECIALBUTTONS; i++) {
        // are any of them pressed?
        if (!digitalRead(specialButtons[i]))
        {                              //this button is pressed
          if(specialButtonsPressed[i] != 1)
            Serial.println(specialButtonsPressed[i], DEC);
            switch (specialButtons[i]) {
            case pinBtnPwr:
              Keyboard.press(KEY_LEFT_CTRL);
              Keyboard.press(KEY_LEFT_ALT);
              Keyboard.press(KEY_DELETE);
              Keyboard.releaseAll();
              digitalWrite(pinLedPower, HIGH);
            case pinBtnBatteryLevel:
              Keyboard.press(KEY_SCROLL_LOCK);
              Keyboard.press(KEY_PRINTSCREEN);
            default:
            // Don't process the button again until released and pressed
            specialButtonsPressed[i]=1;
          // Button released - process on next press
          specialButtonsPressed[i]=0;
    25,223
    Quote Originally Posted by richteel View Post
    Yes, that's perfectly normal. The teensy_reboot utility only "knows" about the standard device configurations. If you change things too much, it can't figure out which device to send the reboot request.
    Jan 2015
    6
    Thanks, I assume that is true for the Serial Monitor as well?
