xxxajk
Does what it says in the title.
Adds ability to not compile any USB stuff at all on teensy 3.x so you can write your own.
Please test with latest teensyduino core.
Please note that 'Serial' won't exist. Use Serial1 to verify that it works for you.
Uploading will still work as usual.
If you have any compile problems, let me know and I can fix them.
boards.txt
boards.txt
menu.usb=USB Type
menu.speed=CPU Speed
menu.keys=Keyboard Layout
teensy31.name=Teensy 3.1
teensy31.upload.protocol=halfkay
teensy31.upload.maximum_size=262144
teensy31.upload.maximum_ram_size=65536
teensy31.upload.speed=12000000
teensy31.upload.disable_flushing=true
teensy31.bootloader.path=undefined
teensy31.serial.restart_cmd=true
teensy31.serial.safe_baud_rates_only=true
teensy31.upload.avrdude_wrapper=teensy_reboot
teensy31.build.mcu=mk20dx256
teensy31.build.cpu=cortex-m4
teensy31.build.option1=-mthumb
teensy31.build.option2=-nostdlib
teensy31.build.option3=-D__MK20DX256__
teensy31.build.option4=-DTEENSYDUINO=120
#uncomment these 3 lines for use with Visual Micro + Studio 6
#teensy31.build.option5=-DF_CPU=96000000
#teensy31.build.option6=-DUSB_SERIAL
#teensy31.build.option7=-DLAYOUT_US_ENGLISH
teensy31.build.cppoption1=-fno-rtti
teensy31.build.linkoption1=-mthumb
teensy31.build.linkoption2=--specs=nano.specs
teensy31.build.additionalobject1=-larm_cortexM4l_math
teensy31.build.linkscript=mk20dx256.ld
teensy31.build.architecture=arm
teensy31.build.command.gcc=arm-none-eabi-gcc
teensy31.build.command.g++=arm-none-eabi-g++
teensy31.build.command.ar=arm-none-eabi-ar
teensy31.build.command.objcopy=arm-none-eabi-objcopy
teensy31.build.command.objdump=arm-none-eabi-objdump
teensy31.build.command.size=arm-none-eabi-size
teensy31.build.core=teensy3
teensy31.build.elide_constructors=true
teensy31.build.gnu0x=true
teensy31.build.dependency=true
teensy31.build.time_t=true
teensy31.build.post_compile_script=teensy_post_compile
teensy31.menu.usb.disabled.name=USB disabled
teensy31.menu.usb.serial.build.define0=-DUSB_DISABLED
teensy31.menu.usb.serial.name=Serial
teensy31.menu.usb.serial.build.define0=-DUSB_SERIAL
teensy31.menu.usb.hid.name=Keyboard + Mouse + Joystick
teensy31.menu.usb.hid.build.define0=-DUSB_HID
teensy31.menu.usb.hid.fake_serial=teensy_gateway
teensy31.menu.usb.serialhid.name=Serial + Keyboard + Mouse + Joystick
teensy31.menu.usb.serialhid.build.define0=-DUSB_SERIAL_HID
teensy31.menu.usb.midi.name=MIDI
teensy31.menu.usb.midi.build.define0=-DUSB_MIDI
teensy31.menu.usb.midi.fake_serial=teensy_gateway
teensy31.menu.usb.rawhid.name=Raw HID
teensy31.menu.usb.rawhid.build.define0=-DUSB_RAWHID
teensy31.menu.usb.rawhid.fake_serial=teensy_gateway
teensy31.menu.usb.flightsim.name=Flight Sim Controls
teensy31.menu.usb.flightsim.build.define0=-DUSB_FLIGHTSIM
teensy31.menu.usb.flightsim.fake_serial=teensy_gateway
#uncomment these if you want to try faster overclocking
#teensy31.menu.speed.168.name=168 MHz (overclock)
#teensy31.menu.speed.144.name=144 MHz (overclock)
#teensy31.menu.speed.120.name=120 MHz (overclock)
teensy31.menu.speed.96.name=96 MHz (overclock)
teensy31.menu.speed.72.name=72 MHz
teensy31.menu.speed.48.name=48 MHz
teensy31.menu.speed.24.name=24 MHz
teensy31.menu.speed.16nousb.name=16 MHz (No USB)
teensy31.menu.speed.8nousb.name=8 MHz (No USB)
teensy31.menu.speed.4nousb.name=4 MHz (No USB)
teensy31.menu.speed.2nousb.name=2 MHz (No USB)
teensy31.menu.speed.168.build.f_cpu=168000000
teensy31.menu.speed.144.build.f_cpu=144000000
teensy31.menu.speed.120.build.f_cpu=120000000
teensy31.menu.speed.96.build.f_cpu=96000000
teensy31.menu.speed.72.build.f_cpu=72000000
teensy31.menu.speed.48.build.f_cpu=48000000
teensy31.menu.speed.24.build.f_cpu=24000000
teensy31.menu.speed.16nousb.build.f_cpu=16000000
teensy31.menu.speed.8nousb.build.f_cpu=8000000
teensy31.menu.speed.4nousb.build.f_cpu=4000000
teensy31.menu.speed.2nousb.build.f_cpu=2000000
teensy31.menu.keys.en-us.name=US English
teensy31.menu.keys.en-us.build.define1=-DLAYOUT_US_ENGLISH
teensy31.menu.keys.fr-ca.name=Canadian French
teensy31.menu.keys.fr-ca.build.define1=-DLAYOUT_CANADIAN_FRENCH
teensy31.menu.keys.xx-ca.name=Canadian Multilingual
teensy31.menu.keys.xx-ca.build.define1=-DLAYOUT_CANADIAN_MULTILINGUAL
teensy31.menu.keys.cz-cz.name=Czech
teensy31.menu.keys.cz-cz.build.define1=-DLAYOUT_CZECH
teensy31.menu.keys.da-da.name=Danish
teensy31.menu.keys.da-da.build.define1=-DLAYOUT_DANISH
teensy31.menu.keys.fi-fi.name=Finnish
teensy31.menu.keys.fi-fi.build.define1=-DLAYOUT_FINNISH
teensy31.menu.keys.fr-fr.name=French
teensy31.menu.keys.fr-fr.build.define1=-DLAYOUT_FRENCH
teensy31.menu.keys.fr-be.name=French Belgian
teensy31.menu.keys.fr-be.build.define1=-DLAYOUT_FRENCH_BELGIAN
teensy31.menu.keys.fr-ch.name=French Swiss
teensy31.menu.keys.fr-ch.build.define1=-DLAYOUT_FRENCH_SWISS
teensy31.menu.keys.de-de.name=German
teensy31.menu.keys.de-de.build.define1=-DLAYOUT_GERMAN
teensy31.menu.keys.de-dm.name=German (Mac)
teensy31.menu.keys.de-dm.build.define1=-DLAYOUT_GERMAN_MAC
teensy31.menu.keys.de-ch.name=German Swiss
teensy31.menu.keys.de-ch.build.define1=-DLAYOUT_GERMAN_SWISS
teensy31.menu.keys.is-is.name=Icelandic
teensy31.menu.keys.is-is.build.define1=-DLAYOUT_ICELANDIC
teensy31.menu.keys.en-ie.name=Irish
teensy31.menu.keys.en-ie.build.define1=-DLAYOUT_IRISH
teensy31.menu.keys.it-it.name=Italian
teensy31.menu.keys.it-it.build.define1=-DLAYOUT_ITALIAN
teensy31.menu.keys.no-no.name=Norwegian
teensy31.menu.keys.no-no.build.define1=-DLAYOUT_NORWEGIAN
teensy31.menu.keys.pt-pt.name=Portuguese
teensy31.menu.keys.pt-pt.build.define1=-DLAYOUT_PORTUGUESE
teensy31.menu.keys.pt-br.name=Portuguese Brazilian
teensy31.menu.keys.pt-br.build.define1=-DLAYOUT_PORTUGUESE_BRAZILIAN
teensy31.menu.keys.rs-rs.name=Serbian (Latin Only)
teensy31.menu.keys.rs-rs.build.define1=-DLAYOUT_SERBIAN_LATIN_ONLY
teensy31.menu.keys.es-es.name=Spanish
teensy31.menu.keys.es-es.build.define1=-DLAYOUT_SPANISH
teensy31.menu.keys.es-mx.name=Spanish Latin America
teensy31.menu.keys.es-mx.build.define1=-DLAYOUT_SPANISH_LATIN_AMERICA
teensy31.menu.keys.sv-se.name=Swedish
teensy31.menu.keys.sv-se.build.define1=-DLAYOUT_SWEDISH
teensy31.menu.keys.tr-tr.name=Turkish (partial)
teensy31.menu.keys.tr-tr.build.define1=-DLAYOUT_TURKISH
teensy31.menu.keys.en-gb.name=United Kingdom
teensy31.menu.keys.en-gb.build.define1=-DLAYOUT_UNITED_KINGDOM
teensy31.menu.keys.usint.name=US International
teensy31.menu.keys.usint.build.define1=-DLAYOUT_US_INTERNATIONAL
teensy3.name=Teensy 3.0
teensy3.upload.protocol=halfkay
teensy3.upload.maximum_size=131072
teensy3.upload.maximum_ram_size=16384
teensy3.upload.speed=12000000
teensy3.upload.disable_flushing=true
teensy3.bootloader.path=undefined
teensy3.serial.restart_cmd=true
teensy3.serial.safe_baud_rates_only=true
teensy3.upload.avrdude_wrapper=teensy_reboot
teensy3.build.mcu=mk20dx128
teensy3.build.cpu=cortex-m4
teensy3.build.option1=-mthumb
teensy3.build.option2=-nostdlib
teensy3.build.option3=-D__MK20DX128__
teensy3.build.option4=-DTEENSYDUINO=120
teensy3.build.cppoption1=-fno-rtti
teensy3.build.linkoption1=-mthumb
teensy3.build.linkoption2=--specs=nano.specs
teensy3.build.additionalobject1=-larm_cortexM4l_math
teensy3.build.linkscript=mk20dx128.ld
teensy3.build.architecture=arm
teensy3.build.command.gcc=arm-none-eabi-gcc
teensy3.build.command.g++=arm-none-eabi-g++
teensy3.build.command.ar=arm-none-eabi-ar
teensy3.build.command.objcopy=arm-none-eabi-objcopy
teensy3.build.command.objdump=arm-none-eabi-objdump
teensy3.build.command.size=arm-none-eabi-size
teensy3.build.core=teensy3
teensy3.build.elide_constructors=true
teensy3.build.gnu0x=true
teensy3.build.dependency=true
teensy3.build.time_t=true
teensy3.build.post_compile_script=teensy_post_compile
teensy3.menu.usb.disabled.name=USB disabled
teensy3.menu.usb.serial.build.define0=-DUSB_DISABLED
teensy3.menu.usb.serial.name=Serial
teensy3.menu.usb.serial.build.define0=-DUSB_SERIAL
teensy3.menu.usb.hid.name=Keyboard + Mouse + Joystick
teensy3.menu.usb.hid.build.define0=-DUSB_HID
teensy3.menu.usb.hid.fake_serial=teensy_gateway
teensy3.menu.usb.serialhid.name=Serial + Keyboard + Mouse + Joystick
teensy3.menu.usb.serialhid.build.define0=-DUSB_SERIAL_HID
teensy3.menu.usb.midi.name=MIDI
teensy3.menu.usb.midi.build.define0=-DUSB_MIDI
teensy3.menu.usb.midi.fake_serial=teensy_gateway
teensy3.menu.usb.rawhid.name=Raw HID
teensy3.menu.usb.rawhid.build.define0=-DUSB_RAWHID
teensy3.menu.usb.rawhid.fake_serial=teensy_gateway
teensy3.menu.usb.flightsim.name=Flight Sim Controls
teensy3.menu.usb.flightsim.build.define0=-DUSB_FLIGHTSIM
teensy3.menu.usb.flightsim.fake_serial=teensy_gateway
teensy3.menu.speed.96.name=96 MHz (overclock)
teensy3.menu.speed.48.name=48 MHz
teensy3.menu.speed.24.name=24 MHz
teensy3.menu.speed.96.build.f_cpu=96000000
teensy3.menu.speed.48.build.f_cpu=48000000
teensy3.menu.speed.24.build.f_cpu=24000000
teensy3.menu.keys.en-us.name=US English
teensy3.menu.keys.en-us.build.define1=-DLAYOUT_US_ENGLISH
teensy3.menu.keys.fr-ca.name=Canadian French
teensy3.menu.keys.fr-ca.build.define1=-DLAYOUT_CANADIAN_FRENCH
teensy3.menu.keys.xx-ca.name=Canadian Multilingual
teensy3.menu.keys.xx-ca.build.define1=-DLAYOUT_CANADIAN_MULTILINGUAL
teensy3.menu.keys.cz-cz.name=Czech
teensy3.menu.keys.cz-cz.build.define1=-DLAYOUT_CZECH
teensy3.menu.keys.da-da.name=Danish
teensy3.menu.keys.da-da.build.define1=-DLAYOUT_DANISH
teensy3.menu.keys.fi-fi.name=Finnish
teensy3.menu.keys.fi-fi.build.define1=-DLAYOUT_FINNISH
teensy3.menu.keys.fr-fr.name=French
teensy3.menu.keys.fr-fr.build.define1=-DLAYOUT_FRENCH
teensy3.menu.keys.fr-be.name=French Belgian
teensy3.menu.keys.fr-be.build.define1=-DLAYOUT_FRENCH_BELGIAN
teensy3.menu.keys.fr-ch.name=French Swiss
teensy3.menu.keys.fr-ch.build.define1=-DLAYOUT_FRENCH_SWISS
teensy3.menu.keys.de-de.name=German
teensy3.menu.keys.de-de.build.define1=-DLAYOUT_GERMAN
teensy3.menu.keys.de-dm.name=German (Mac)
teensy3.menu.keys.de-dm.build.define1=-DLAYOUT_GERMAN_MAC
teensy3.menu.keys.de-ch.name=German Swiss
teensy3.menu.keys.de-ch.build.define1=-DLAYOUT_GERMAN_SWISS
teensy3.menu.keys.is-is.name=Icelandic
teensy3.menu.keys.is-is.build.define1=-DLAYOUT_ICELANDIC
teensy3.menu.keys.en-ie.name=Irish
teensy3.menu.keys.en-ie.build.define1=-DLAYOUT_IRISH
teensy3.menu.keys.it-it.name=Italian
teensy3.menu.keys.it-it.build.define1=-DLAYOUT_ITALIAN
teensy3.menu.keys.no-no.name=Norwegian
teensy3.menu.keys.no-no.build.define1=-DLAYOUT_NORWEGIAN
teensy3.menu.keys.pt-pt.name=Portuguese
teensy3.menu.keys.pt-pt.build.define1=-DLAYOUT_PORTUGUESE
teensy3.menu.keys.pt-br.name=Portuguese Brazilian
teensy3.menu.keys.pt-br.build.define1=-DLAYOUT_PORTUGUESE_BRAZILIAN
teensy3.menu.keys.es-es.name=Spanish
teensy3.menu.keys.es-es.build.define1=-DLAYOUT_SPANISH
teensy3.menu.keys.es-mx.name=Spanish Latin America
teensy3.menu.keys.es-mx.build.define1=-DLAYOUT_SPANISH_LATIN_AMERICA
teensy3.menu.keys.sv-se.name=Swedish
teensy3.menu.keys.sv-se.build.define1=-DLAYOUT_SWEDISH
teensy3.menu.keys.tr-tr.name=Turkish (partial)
teensy3.menu.keys.tr-tr.build.define1=-DLAYOUT_TURKISH
teensy3.menu.keys.en-gb.name=United Kingdom
teensy3.menu.keys.en-gb.build.define1=-DLAYOUT_UNITED_KINGDOM
teensy3.menu.keys.usint.name=US International
teensy3.menu.keys.usint.build.define1=-DLAYOUT_US_INTERNATIONAL
teensy2.name=Teensy 2.0
teensy2.upload.protocol=halfkay
teensy2.upload.maximum_size=32256
teensy2.upload.maximum_ram_size=2560
teensy2.upload.speed=12000000
teensy2.upload.disable_flushing=true
teensy2.bootloader.path=undefined
teensy2.serial.restart_cmd=true
teensy2.serial.safe_baud_rates_only=true
teensy2.upload.avrdude_wrapper=teensy_reboot
teensy2.build.mcu=atmega32u4
teensy2.build.option1=-DTEENSYDUINO=120
teensy2.build.core=teensy
teensy2.build.elide_constructors=true
teensy2.build.cpp0x=true
teensy2.build.dependency=true
teensy2.build.linker_relaxation=true
teensy2.build.post_compile_script=teensy_post_compile
teensy2.build.serial_number=true
teensy2.menu.usb.serial.name=Serial
teensy2.menu.usb.serial.build.define0=-DUSB_SERIAL
teensy2.menu.usb.hid.name=Keyboard + Mouse + Joystick
teensy2.menu.usb.hid.build.define0=-DUSB_HID
teensy2.menu.usb.hid.fake_serial=teensy_gateway
teensy2.menu.usb.serialhid.name=Serial + Keyboard + Mouse + Joystick
teensy2.menu.usb.serialhid.build.define0=-DUSB_SERIAL_HID
teensy2.menu.usb.int_disk.name=Disk(Internal) + Keyboard
teensy2.menu.usb.int_disk.build.define0=-DUSB_DISK
teensy2.menu.usb.int_disk.fake_serial=teensy_gateway
teensy2.menu.usb.int_disk.build.elfpatch=mktinyfat
teensy2.menu.usb.sd_disk.name=Disk(SD Card) + Keyboard
teensy2.menu.usb.sd_disk.build.define0=-DUSB_DISK_SDFLASH
teensy2.menu.usb.sd_disk.fake_serial=teensy_gateway
teensy2.menu.usb.midi.name=MIDI
teensy2.menu.usb.midi.build.define0=-DUSB_MIDI
teensy2.menu.usb.midi.fake_serial=teensy_gateway
teensy2.menu.usb.rawhid.name=Raw HID
teensy2.menu.usb.rawhid.build.define0=-DUSB_RAWHID
teensy2.menu.usb.rawhid.fake_serial=teensy_gateway
teensy2.menu.usb.flightsim.name=Flight Sim Controls
teensy2.menu.usb.flightsim.build.define0=-DUSB_FLIGHTSIM
teensy2.menu.usb.flightsim.fake_serial=teensy_gateway
teensy2.menu.speed.16.name=16 MHz
teensy2.menu.speed.8.name=8 MHz
teensy2.menu.speed.4.name=4 MHz
teensy2.menu.speed.2.name=2 MHz
teensy2.menu.speed.1.name=1 MHz
teensy2.menu.speed.16.build.f_cpu=16000000L
teensy2.menu.speed.8.build.f_cpu=8000000L
teensy2.menu.speed.4.build.f_cpu=4000000L
teensy2.menu.speed.2.build.f_cpu=2000000L
teensy2.menu.speed.1.build.f_cpu=1000000L
teensy2.menu.keys.en-us.name=US English
teensy2.menu.keys.en-us.build.define1=-DLAYOUT_US_ENGLISH
teensy2.menu.keys.fr-ca.name=Canadian French
teensy2.menu.keys.fr-ca.build.define1=-DLAYOUT_CANADIAN_FRENCH
teensy2.menu.keys.xx-ca.name=Canadian Multilingual
teensy2.menu.keys.xx-ca.build.define1=-DLAYOUT_CANADIAN_MULTILINGUAL
teensy2.menu.keys.cz-cz.name=Czech
teensy2.menu.keys.cz-cz.build.define1=-DLAYOUT_CZECH
teensy2.menu.keys.da-da.name=Danish
teensy2.menu.keys.da-da.build.define1=-DLAYOUT_DANISH
teensy2.menu.keys.fi-fi.name=Finnish
teensy2.menu.keys.fi-fi.build.define1=-DLAYOUT_FINNISH
teensy2.menu.keys.fr-fr.name=French
teensy2.menu.keys.fr-fr.build.define1=-DLAYOUT_FRENCH
teensy2.menu.keys.fr-be.name=French Belgian
teensy2.menu.keys.fr-be.build.define1=-DLAYOUT_FRENCH_BELGIAN
teensy2.menu.keys.fr-ch.name=French Swiss
teensy2.menu.keys.fr-ch.build.define1=-DLAYOUT_FRENCH_SWISS
teensy2.menu.keys.de-de.name=German
teensy2.menu.keys.de-de.build.define1=-DLAYOUT_GERMAN
teensy2.menu.keys.de-dm.name=German (Mac)
teensy2.menu.keys.de-dm.build.define1=-DLAYOUT_GERMAN_MAC
teensy2.menu.keys.de-ch.name=German Swiss
teensy2.menu.keys.de-ch.build.define1=-DLAYOUT_GERMAN_SWISS
teensy2.menu.keys.is-is.name=Icelandic
teensy2.menu.keys.is-is.build.define1=-DLAYOUT_ICELANDIC
teensy2.menu.keys.en-ie.name=Irish
teensy2.menu.keys.en-ie.build.define1=-DLAYOUT_IRISH
teensy2.menu.keys.it-it.name=Italian
teensy2.menu.keys.it-it.build.define1=-DLAYOUT_ITALIAN
teensy2.menu.keys.no-no.name=Norwegian
teensy2.menu.keys.no-no.build.define1=-DLAYOUT_NORWEGIAN
teensy2.menu.keys.pt-pt.name=Portuguese
teensy2.menu.keys.pt-pt.build.define1=-DLAYOUT_PORTUGUESE
teensy2.menu.keys.pt-br.name=Portuguese Brazilian
teensy2.menu.keys.pt-br.build.define1=-DLAYOUT_PORTUGUESE_BRAZILIAN
teensy2.menu.keys.es-es.name=Spanish
teensy2.menu.keys.es-es.build.define1=-DLAYOUT_SPANISH
teensy2.menu.keys.es-mx.name=Spanish Latin America
teensy2.menu.keys.es-mx.build.define1=-DLAYOUT_SPANISH_LATIN_AMERICA
teensy2.menu.keys.sv-se.name=Swedish
teensy2.menu.keys.sv-se.build.define1=-DLAYOUT_SWEDISH
teensy2.menu.keys.en-gb.name=United Kingdom
teensy2.menu.keys.en-gb.build.define1=-DLAYOUT_UNITED_KINGDOM
teensy2.menu.keys.usint.name=US International
teensy2.menu.keys.usint.build.define1=-DLAYOUT_US_INTERNATIONAL
teensypp2.name=Teensy++ 2.0
teensypp2.upload.protocol=halfkay
teensypp2.upload.maximum_size=130048
teensypp2.upload.maximum_ram_size=8192
teensypp2.upload.speed=12000000
teensypp2.upload.disable_flushing=true
teensypp2.bootloader.path=undefined
teensypp2.serial.restart_cmd=true
teensypp2.serial.safe_baud_rates_only=true
teensypp2.upload.avrdude_wrapper=teensy_reboot
teensypp2.build.mcu=at90usb1286
teensypp2.build.option1=-DTEENSYDUINO=120
teensypp2.build.core=teensy
teensypp2.build.elide_constructors=true
teensypp2.build.cpp0x=true
teensypp2.build.dependency=true
teensypp2.build.linker_relaxation=true
teensypp2.build.post_compile_script=teensy_post_compile
teensypp2.build.serial_number=true
teensypp2.menu.usb.serial.name=Serial
teensypp2.menu.usb.serial.build.define0=-DUSB_SERIAL
teensypp2.menu.usb.hid.name=Keyboard + Mouse + Joystick
teensypp2.menu.usb.hid.build.define0=-DUSB_HID
teensypp2.menu.usb.hid.fake_serial=teensy_gateway
teensypp2.menu.usb.serialhid.name=Serial + Keyboard + Mouse + Joystick
teensypp2.menu.usb.serialhid.build.define0=-DUSB_SERIAL_HID
teensypp2.menu.usb.int_disk.name=Disk(Internal) + Keyboard
teensypp2.menu.usb.int_disk.build.define0=-DUSB_DISK
teensypp2.menu.usb.int_disk.fake_serial=teensy_gateway
teensypp2.menu.usb.int_disk.build.elfpatch=mktinyfat
teensypp2.menu.usb.sd_disk.name=Disk(SD Card) + Keyboard
teensypp2.menu.usb.sd_disk.build.define0=-DUSB_DISK_SDFLASH
teensypp2.menu.usb.sd_disk.fake_serial=teensy_gateway
teensypp2.menu.usb.midi.name=MIDI
teensypp2.menu.usb.midi.build.define0=-DUSB_MIDI
teensypp2.menu.usb.midi.fake_serial=teensy_gateway
teensypp2.menu.usb.rawhid.name=Raw HID
teensypp2.menu.usb.rawhid.build.define0=-DUSB_RAWHID
teensypp2.menu.usb.rawhid.fake_serial=teensy_gateway
teensypp2.menu.usb.flightsim.name=Flight Sim Controls
teensypp2.menu.usb.flightsim.build.define0=-DUSB_FLIGHTSIM
teensypp2.menu.usb.flightsim.fake_serial=teensy_gateway
teensypp2.menu.speed.16.name=16 MHz
teensypp2.menu.speed.8.name=8 MHz
teensypp2.menu.speed.4.name=4 MHz
teensypp2.menu.speed.2.name=2 MHz
teensypp2.menu.speed.1.name=1 MHz
teensypp2.menu.speed.16.build.f_cpu=16000000L
teensypp2.menu.speed.8.build.f_cpu=8000000L
teensypp2.menu.speed.4.build.f_cpu=4000000L
teensypp2.menu.speed.2.build.f_cpu=2000000L
teensypp2.menu.speed.1.build.f_cpu=1000000L
teensypp2.menu.keys.en-us.name=US English
teensypp2.menu.keys.en-us.build.define1=-DLAYOUT_US_ENGLISH
teensypp2.menu.keys.fr-ca.name=Canadian French
teensypp2.menu.keys.fr-ca.build.define1=-DLAYOUT_CANADIAN_FRENCH
teensypp2.menu.keys.xx-ca.name=Canadian Multilingual
teensypp2.menu.keys.xx-ca.build.define1=-DLAYOUT_CANADIAN_MULTILINGUAL
teensypp2.menu.keys.cz-cz.name=Czech
teensypp2.menu.keys.cz-cz.build.define1=-DLAYOUT_CZECH
teensypp2.menu.keys.da-da.name=Danish
teensypp2.menu.keys.da-da.build.define1=-DLAYOUT_DANISH
teensypp2.menu.keys.fi-fi.name=Finnish
teensypp2.menu.keys.fi-fi.build.define1=-DLAYOUT_FINNISH
teensypp2.menu.keys.fr-fr.name=French
teensypp2.menu.keys.fr-fr.build.define1=-DLAYOUT_FRENCH
teensypp2.menu.keys.fr-be.name=French Belgian
teensypp2.menu.keys.fr-be.build.define1=-DLAYOUT_FRENCH_BELGIAN
teensypp2.menu.keys.fr-ch.name=French Swiss
teensypp2.menu.keys.fr-ch.build.define1=-DLAYOUT_FRENCH_SWISS
teensypp2.menu.keys.de-de.name=German
teensypp2.menu.keys.de-de.build.define1=-DLAYOUT_GERMAN
teensypp2.menu.keys.de-dm.name=German (Mac)
teensypp2.menu.keys.de-dm.build.define1=-DLAYOUT_GERMAN_MAC
teensypp2.menu.keys.de-ch.name=German Swiss
teensypp2.menu.keys.de-ch.build.define1=-DLAYOUT_GERMAN_SWISS
teensypp2.menu.keys.is-is.name=Icelandic
teensypp2.menu.keys.is-is.build.define1=-DLAYOUT_ICELANDIC
teensypp2.menu.keys.en-ie.name=Irish
teensypp2.menu.keys.en-ie.build.define1=-DLAYOUT_IRISH
teensypp2.menu.keys.it-it.name=Italian
teensypp2.menu.keys.it-it.build.define1=-DLAYOUT_ITALIAN
teensypp2.menu.keys.no-no.name=Norwegian
teensypp2.menu.keys.no-no.build.define1=-DLAYOUT_NORWEGIAN
teensypp2.menu.keys.pt-pt.name=Portuguese
teensypp2.menu.keys.pt-pt.build.define1=-DLAYOUT_PORTUGUESE
teensypp2.menu.keys.pt-br.name=Portuguese Brazilian
teensypp2.menu.keys.pt-br.build.define1=-DLAYOUT_PORTUGUESE_BRAZILIAN
teensypp2.menu.keys.es-es.name=Spanish
teensypp2.menu.keys.es-es.build.define1=-DLAYOUT_SPANISH
teensypp2.menu.keys.es-mx.name=Spanish Latin America
teensypp2.menu.keys.es-mx.build.define1=-DLAYOUT_SPANISH_LATIN_AMERICA
teensypp2.menu.keys.sv-se.name=Swedish
teensypp2.menu.keys.sv-se.build.define1=-DLAYOUT_SWEDISH
teensypp2.menu.keys.en-gb.name=United Kingdom
teensypp2.menu.keys.en-gb.build.define1=-DLAYOUT_UNITED_KINGDOM
teensypp2.menu.keys.usint.name=US International
teensypp2.menu.keys.usint.build.define1=-DLAYOUT_US_INTERNATIONAL
