Page 13 of 22 FirstFirst ... 3 11 12 13 14 15 ... LastLast
Results 301 to 325 of 550
Thread: Coming Soon: Teensy-LC (low cost Teensy)
  1. #301
    Senior Member duff's Avatar
    Las Vegas
    969
    Try "sub" instead of "subs".
    Really, the assembler should accept "subs", since the status bits are always updated. But this looks like a quick in the assembler.
    But you'll need a #ifdef, to use "sub" on Teensy-LC and "subs" on the others. Yeah, it's messy.
    I found that if you look at the disassembly of the asm for delayMicroseconds it uses 'subs'
    00000472 <L_10_delayMicroseconds>:
         472:       3b01            subs    r3, #1
         474:       d1fd            bne.n   472 <L_10_delayMicroseconds>
         476:       4770            bx      lr
         478:       00027100        .word   0x00027100
    I had some issues with this and other instructions that try to set flags for inline assembly.
    The assembler complains with this error
    Error: instruction not supported in Thumb16 mode -- `subs r3,#1'
    I don't know gcc/gas arm syntax or I'd fix it myself.
    You can use asm (".syntax unified"); before the subs instruction and then asm (".syntax divided"); after it and it will compile so something like this would compile:
    static __inline__ void      /* exactly 4 cycles/loop, max 2**32 loops */
    _delay_loop_2_x( uint32_t __n )
    {                                               /* cycles per loop      */
        __asm__ volatile (                          /* __n..one        zero */
                    "L_%=__delay_loop_2_x:"               "\n\t"
                    ".syntax unified"                     "\n\t"
                    "subs   %0, #1"                       "\n\t"
                    ".syntax divided"                     "\n\t"
    //                "nop"                               "\n\t"
                    "bne    L_%=__delay_loop_2_x"         "\n"
                    : "+r" (__n) :
    the disassembly looks good to me:
    00000476 <L_19__delay_loop_2_x>:
         476:       3b01            subs    r3, #1
         478:       d1fd            bne.n   476 <L_19__delay_loop_2_x>
         47a:       4770            bx      lr
         47c:       00002710        .word   0x00002710
  2. #302
    20,554
    Quote Originally Posted by duff View Post
    Yes, it's absolutely terrible.
    But that's the way the toolchain is, where you have to write "sub" which really means "subs" (it does in fact update the status bits) and gets disassembled as "subs".
  3. #303
    Dallas, TX USA
    106
    WOW. That sucks. Seems like a tool bug to me, since the assembler and the disassembler don't agree on the mnemonics.
    I can't imagine the amount of time wasted spent trying to figure that one out.
    That fixed it.
    Is there a better define rather than using the processor define of __MKL26Z64__ to indicate that "thumb" mode
    is being used and "sub" must be used instead of "subs"
    i.e. I'd like to test a define that works on any ARM processor using thumb mode vs just this specific one to put this
    code to bed vs having to fix it later in the future.
    --- bill
  4. #304
    3,252
    I believe in the full ARM instruction set there is both SUB (does not set condition code fields) and SUBS (does set condition code fields). However in thumb16, there is only SUB and it sets the condition code fields always. The GCC compiler defines __thumb__ and __thumb2__, depending on which thumb instruction set is used.
  5. #305
    Dallas, TX USA
    106
    Have some questions on pin i/o.
    Maybe this isn't the best thread for this, but I'll start off here.
    Currently openGLCD jumps through lots of hoops to try to do the fastest
    pin i/o as possible. On the AVR that drops down to direct port i/o and can
    even do multi bit nibbles or even byte i/o when possible.
    On the Teensy arm processors, it uses digitalReadFast()/digitalWriteFast() which
    are a bit faster than digitalRead()/digitalWrite() but no where near
    as fast as the raw port i/o on the AVR even thought the AVR overall is a
    significantly slower processor.
    So the first question is:
    Is there a better form of pin i/o available on the teensy arm based products?
    The second question is:
    Is there way other than having to check for CORE_TEENSY and then the processor types
    to detect when digitalReadFast()/digitalWrite() exists?
    i.e. on other platforms those are implemented as macros so I can simply check for
    their existence but on Teensy they are implemented directly as inline functions so you
    can't check for their existence.
    --- bill
  6. #306
    20,554
    Quote Originally Posted by bperrybap View Post
    Just a few minutes, actually, the first time I hit this while porting delayMicroseconds().
    I'm pretty familiar with the ARM Cortex-M (thumb2) assembly language.
  7. #307
    Dallas, TX USA
    106
    So it looks like __thumb__ is the defined when using thumb16 where "subs" can't be used.
    Thanks.
    Another question, out of curiosity, is thumb16 a locked in mode for a given processor or is something that
    can change depending on how the code is compiled through command line or optimization options?
    --- bill
  8. #308
    3,252
    I don't really know the arm all that well, but I believe it depends. Some processors are ARM-only, some are Thumb-only, and some can have ARM/thumb code in the same context, and use a mode context swap instruction to switch between the two.
  9. #309
    Dallas, TX USA
    106
    Great so using the __thumb__ define is definitely the way to go vs using a processor define.
    Thanks again.
    --- bill
  10. #310
    Dallas, TX USA
    106
    One thing I still need to get resolved is can the LC 3v pin inputs tolerate a 5v output when fed through a 10k series resistor
    like the Teensy 3 could?
  11. #311
    20,554
    All Cortex-M chips are thumb instructions only. If you ever try switch to ARM state, the processor goes to fault mode.
    Cortex-M0+ supports only the v6m instructions. Cortex-M3 and Cortex-M4 support the much larger v7m instruction set, and M4 adds the special DSP instructions.
    I too would like to know if there's a reliable set of gcc built-in defines to distinguish between all these cases.
  12. #312
    20,554
    One thing I still need to get resolved is can the LC 3v pin inputs tolerate a 5v output when fed through a 10k series resistor like the Teensy 3 could?
    Yes, it can.
    As with Teensy 3.0, the caveat is the total injected current on all pins must always be less than the current consumption of the entire chip. Rarely is this an issue while the chip is running, but you have to be careful if using the very low power modes.
  13. #313
    Dallas, TX USA
    106
    Just as a followup, __thumb__ is defined when building for Teensy 3.0 and for Teensy LC so that define isn't the magic bullet.
    --- bill
  14. #314
    20,554
    My headers define KINETISK and KINETISL. That's hardly as authoritative as a gcc builtin, but so far I've been going with those.
  15. #315
    Dallas, TX USA
    106
    Missing error information
    Just ran into a strange issue in the 1.21-beta6 on the 1.6 IDE
    There seems to be an issue with the error output when building for teensy boards.
    I see this when a #error is encountered.
    If I build for uno, I can see what I expect and the useful information like the file, line number, and error message is at the bottom
    of the red output. When I build for any teensy board the output is truncated and I am not getting the error information.
    I tossed a #error into a header file and this is what I get when building for Teensy++/Teensy 3.0 or Teensy LC: (all teensy boards)
    Arduino: 1.6.0 (Linux), TD: 1.21-beta6, Board: "Teensy 3.0, Serial, 96 MHz (overclock), US English"
    Build options changed, rebuilding all
    Using library openGLCD in folder: /media/UbuntuRoot/home/bill/Arduino/Arduino-AVR/libraries/openGLCD (legacy)
    /media/DataPartition/2B-Organized/devel/avr/arduino/arduino-1.6.0-bap/hardware/tools/arm/bin/arm-none-eabi-g++ -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX128__ -DTEENSYDUINO=121 -DARDUINO=10600 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/media/DataPartition/2B-Organized/devel/avr/arduino/arduino-1.6.0-bap/hardware/teensy/avr/cores/teensy3 -I/media/UbuntuRoot/home/bill/Arduino/Arduino-AVR/libraries/openGLCD /tmp/build1859051540936981105.tmp/GLCDdiags.cpp -o /tmp/build1859051540936981105.tmp/GLCDdiags.cpp.o
    In file included from /media/UbuntuRoot/home/bill/Arduino/Arduino-AVR/libraries/openGLCD/include/glcd_Device.h:36:0,
                     from /media/UbuntuRoot/home/bill/Arduino/Arduino-AVR/libraries/openGLCD/include/gText.h:36,
                     from /media/UbuntuRoot/home/bill/Arduino/Arduino-AVR/libraries/openGLCD/include/glcd.h:41,
                     from /media/UbuntuRoot/home/bill/Arduino/Arduino-AVR/libraries/openGLCD/openGLCD.h:5,
                     from GLCDdiags.pde:45:
    Error compiling.
    And this is what I get when building with the exact same IDE but for UNO:
    Arduino: 1.6.0 (Linux), TD: 1.21-beta6, Board: "Arduino Uno"
    /media/DataPartition/2B-Organized/devel/avr/arduino/arduino-1.6.0-bap/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10600 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/media/DataPartition/2B-Organized/devel/avr/arduino/arduino-1.6.0-bap/hardware/arduino/avr/cores/arduino -I/media/DataPartition/2B-Organized/devel/avr/arduino/arduino-1.6.0-bap/hardware/arduino/avr/variants/standard -I/media/UbuntuRoot/home/bill/Arduino/Arduino-AVR/libraries/openGLCD /tmp/build1859051540936981105.tmp/GLCDdiags.cpp -o /tmp/build1859051540936981105.tmp/GLCDdiags.cpp.o
    /media/UbuntuRoot/home/bill/Arduino/Arduino-AVR/libraries/openGLCD/include/glcd_io.h:1:2: error: #error XXX
     #error XXX
    In file included from GLCDdiags.pde:47:0:
     #error XXX
    There must be some sort of output error parsing that is different for Teensy that is dropping the information.
    It is pretty important information so obviously it needs some tweaking.
    --- bill
  16. #316
    Las Vegas
    969
    https://forum.pjrc.com/threads/27867...error-messages
  17. #317
    Dallas, TX USA
    106
    Yes, it can.
    Something is different with the LC vs the 3.
    I tried using 10k series resistors instead of the level shifter and the LC
    doesn't seem to be a able to reliably read the 5v signal levels which
    ends up putting trash on the display.
    I don't believe it is a timing issue as the Teensy 3.0 works even when clocking at 96Mhz and I've also forced the LC
    to use the much slower Arduino delayMicroseconds() call which should give much longer than needed delays.
    If I turn off all data reads, and use the write cache, then it works fine with the LC so the issue is definitely
    on the read side.
    I've also tried dropping back to standard digitalRead()/digitalWrite() instead of the "fast" versions
    and no difference.
    I'll hook up a logic analyzer and report back but I'm not expecting an issue with the delays.
    I don't have a scope so I can't look for analog type corruption on the signals.
    Any ideas?
    --- bill
  18. #318
    2,191
    --- bill
    tell me more. are you using INPUT_PULLUP on teensy side? how fast is input signal changing? what is source of 5v signal?
  19. #319
    20,554
    Here is a first draft for the front side of the reference card.
  20. #320
    Sep 2013
    Hamburg, Germany
    891
    Why are the labels for pins 5, 16, 17 and 21 bold?
    There is hardly any difference in the colors for digital pins and serial ports - maybe make it more prominent?
  21. #321
    1,408
    That's likely an oversight.
  22. #322
    2,191
    On 3.* cards, pin between Vin and 3.3v was marked as AGND
    and shouldn't A12/DAC be 26 not 17?
    the red dots for 20ma pins was nice addition as per Nantonos draft, though I guess your bold for 5,16,17,21 conveys that info (steganography)
  23. #323
    3,252
    Just to be sure are both digital pins 3 and 21 alternates for RX1 and digital pins 4 and 5 alternates for TX1?
  24. #324
    2,191
    i think that is right according to this earlier attachment
    https://forum.pjrc.com/attachment.ph...2&d=1424103301
  25. #325
    5,416
    There are probably a few other alternate pins that potentially could be marked. Example CS on pin 2?
    Also my built table could be wrong, but wondering about PWM on pin 21?
