Page 3 of 22 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 51 to 75 of 550
Thread: Coming Soon: Teensy-LC (low cost Teensy)
  1. #51
    Jun 2013
    So. Calif
    2,828
    UART and DMA
    I've been using UART TX DMA - to offset the lack of hardware FIFOs in the UARTs. A 16 deep FIFO (common in UARTS) can interrupt at 75% or so, and thereby reduce the interrupts per second by more than a factor of 10.
    At 115.2Kbaud and without a FIFO and no DMA, that's 11,000 interrupts per second. It's not that a UART sustains that rate, but the burst of interrupts can disrupt other code's timing. And even 11K/sec requires some decent interrupt latency and no sloppy code that blocks interrupts too long.
    Some M4's also lack a hardware timer in the UART to interrupt on the receive side if n character times go by with no (more) incoming data. Data Timeout some say.This helps a bit. The NXP ARM7's had a good UART.
    One case I saw, and want to implement, is to use one of the ARM's timers, where the timer reset cause is setup to be a transition on the UART RX pin. Thus, when RX data ceases, or never occurred, the timer interrupts and one can attend to the UART RX.
    Another case I saw was setting up RX DMA with a circular buffer, and have the DMA interrupt when the DMA address wraps the circular buffer.. that being a counter that was set when the circular buffer's address and size was sent to the DMA controller. I suppose a timer is also needed, for the no-data-present case.
    Why do they cheap-out and use UARTs lacking FIFOs??? How much $ can that save?
  2. #52
    Boston, MA, USA
    1,103
    This could still use a bit of tidying, a high res image (and the card for the back).
    Edit: corrections
    - typos for plural I2S and SPI ports
    - pin 21 is 20mA
    card-lc-top.zip
    card-lc-top.pdf
  3. #53
    Feb 2013
    533
    oh, thanks! (and thanks for being on the list)!
    i've only just seen this now ... ha, i guess it's too late now to say i'm happy to step back from the purple ones because of shipping etc to places outside the US.
    Christoph,
    Maybe we can organize a bulk order, and thereby save on postage (for the green ones)
    Vielleicht können wir ja eine Sammelbestellung organisieren um zu Porto sparen.
    Gibt es ja noch mehr User aus Deutschland ?
    i'd be in!
  4. #54
    Jun 2013
    So. Calif
    2,828
    @nantonos
    Very nice work on the crib card.
    Nit: Plural on the purple I2C Ports and below it, SPI Ports
  5. #55
    Thanks Paul for including me on the list! I always have time for some beta testing.
    I live in Europe, Germany. Let me know how we can make it happen. Maybe the Teensy-LC
    would be also interesting for our upcoming Hardware Maker Space here in Berlin.
  6. #56
    Boston, MA, USA
    1,103
    Thanks, fixed.
  7. #57
    19
    Quote Originally Posted by syso2342 View Post
    Hi there, i am also in Berlin and could do some MIDI-DIN / MIDI-USB related testing.
    As i have a breakout using the 3.1 to drive solenoids with MIDI Signals.
    Also Friends of mine have around 80 boards with wiflys to wirlessly drive WS2812B LED strips.
    >https://www.tindie.com/products/zedl...ed-controller/
    @mxxx @syso2342 @Frank B @christoph
    If we get a batch together i could split the package and hand them over or make smaller envelopes and send them to you.
    @paul - thanks for the amazing work!
  8. #58
    Sep 2013
    Hamburg, Germany
    886
    I've asked paul what he thinks about a bulk package to germany
  9. #59
    Feb 2013
    533
    Quote Originally Posted by nevvkid View Post
    sounds good -- i'm in berlin, too.
  10. #60
    19
    Quote Originally Posted by mxxx View Post
    Nice! We should have a Teensy Noisemakers Meetup
  11. #61
    Administrator Robin's Avatar
    Oct 2012
    PJRC Global Headquarters
    283
    I think we can arrange a batch shipment to Germany.
  12. #62
    Jun 2013
    So. Calif
    2,828
    Quote Originally Posted by Robin View Post
    I'll hand-carry for you, to Munich or Garmisch Partenkirchen.
  13. #63
    Senior Member Jp3141's Avatar
    455
    @Paul -- I'm going to Europe on Friday. I'll mail some to people in Europe for you if you want & can get them to me by 10am Fri morning in the US.
  14. #64
    18,657
    We're going to ship the first 9 on Monday.
    Edit: sometime over the weekend, Robin & I make the arbitrary/unfair decisions on who gets these first boards.
    The decisions on shipping are up to Robin. She'll be doing all the shipping stuff, which lets me stay focused on the tech side.
  15. #65
    1,642
    looking forward to a little TLC
    Re: internal ADC regs on teensy LC
    From the ref/datasheet docs it appears that TLC has the same chip temperature sensor register (AD26) as teensy 3.0 and 3.1, but TLC does not have VREF output (AD22 on teensy 3.0), so you can't use analogRead(39) to, for example, check the battery voltage level against VREF output (1.195v). HOWEVER, for the TLC one could use the bandgap (AD27) at 1.0v.
    I did a quick test on the teensy 3.0, hacking analog.c and replacing AD22 with AD27, and in the sketch using 1000mv in place of 1195 mv to calculate Vcc. You must also enable the Vbg with
    PMC_REGSC |= PMC_REGSC_BGBE;
    That seemed to work, but I may not understand the underlying differences between VREF output as reference vs bandgap.
  16. #66
    19
    Hi stevech.
    Garmisch? Nice. I am actually from Seehausen am Staffelsee - living in Berlin.
  17. #67
    18,657
    I briefly tried the temp sensor while porting the analogRead() code. I got only zeros and I didn't invest more time into why.
    This certainly is something I hope can get worked out next week, when people start getting the boards. But it's also possible the temperature sensor might not actually be supported in this chip?
  18. #68
    Danville, California
    920
    Nice job Nantonos! Isn't pin 21 the 20 mA pin, not pin 20?
    Can I use any of the 5 mA pins as a GND with digitalWrite to sink 20 mA of current. In other words, if I use pin 21 as a 3V3 source for 20 mA in a circuit, can I use pin, say, 4 as the GND? Or does the GND also need to be a 20 mA pin?
  19. #69
    Senior Member Pensive's Avatar
    Aug 2014
    Basingstoke, UK
    552
    Humbled to be listed Thank you Paul
    I am available to beta test now, however I think that the first 9 boards should go to others as i'm in the UK. Happy to pay any additional costs for shipping - its a shame the audio library won't compile yet for simple flash sample playback as I have a mini audio DAC output project in mind for my kids which would be perfect for this platform
    But I would like to play with and make something with it
    I also work in the lighting industry and have designs on a Teensy DALI controller. This chip is PERFECT for whacking in a DIN rail box with a 22v PSU and doing commercial lighting control with.
  20. #70
    18,657
    It's looking like release date is going to be March 10th.
  21. #71
    Boston
    6
    Hi Paul! Daniel Garcia and I would like to get FastLED ready for these, especially with the (awesome!) 5-volt level pin specifically for driving WS2811/WS2812 Neopixels.
    Please let me know what's the best way to get a couple of these new boards to test. Happy to pay for the boards and/or shipping. Thanks very much -- they look like a they'll be right in the sweet spot for a lot of projects.
    -Mark
  22. #72
    2,821
    In looking at the layout of the Teensy-LC, and thinking about neopixel wearables, I wish the 3.3v power in the back was routed to VIN and not 3.3V. Yeah, it would have been another difference from the Teensy-3.x, but it would have allowed attaching the 3 wires for neopixels (power, ground, data) directly to the teensy. You could have used a connector like: https://www.pololu.com/product/2703.
    It isn't a major problem, as I can just use wires to make a connection, but it would have been nice.
  23. #73
    Boston, MA, USA
    1,103
    Quote Originally Posted by onehorse View Post
    Yes, good catch, fixed.
  24. #74
    Nice addition to the line-up. I will buy some for sure, but do not have time for beta testing, sorry.
  25. #75
    Senior Member johnnyfp's Avatar
    New Zealand
    260
    thanks for the include,
    Is the bootloader the same setup? Seems smaller than the mini tan 54, maybe a micro tan?
    Jfp
