Results 1 to 4 of 4
Thread: Teensy 3.1 usb change on the flight
    Jan 2015
    Belgium
    2
    Hi, I would like to know if it is possible to change "usb-type" on the flight: say it emulates a keyboard, and when it gets a scrollLock, it changes vid/pid and becomes a mouse. (This is just an example) Also, could one use the 'raw' usb-specs (bLenght,...) in a sketch
    Thanks, Redfast
    25,225
    Possible, yes. Easy, not so much.
    However, it's easy to be a composite device with both keyboard and mouse at the same time (and joystick too). Just select it in Arduino from the Tools > USB Type menu.
    If you really want to change device types at runtime, you're going to have a lot of programming work. All the existing code is designed to be only a fixed type. Of course, it is theoretically possible. You'll need to disconnect from the USB, which looks like a cable unplug to the PC. Then reconnect, and answer the descriptor requests with different data.
    The key piece of code is probably the usb_descriptor_list array, at line 758 in usb_desc.c.
    https://github.com/PaulStoffregen/co...sb_desc.c#L758
    When the PC requests a descriptor, the USB code reads this list to figure out what data to transmit. As you can see, it's declared as a const variable, and populated with fixed data. Perhaps if you change this to not be const, and re-write it with new info, that might do most of the work. Of course, you'll need to compose the 2 sets of descriptor data.
    If you're crafty, you'll use different endpoints and just keep the existing code for doing both at the same time. If the descriptors don't mention the mouse, the PC won't access that endpoint, even if the first is implementing it. Likewise for keyboard.
    Jan 2015
    Belgium
    2
    Ok, thanks. I'll have a look at it and see what I can do.
    Mar 2017
    3
    Hey,
    I'm want to accomplish something similar. Basically I'm want to make the device-descriptor changeable at runtime.
    The idee is to override the descriptor in usb_dev.c. But I'm not really sure if it will work. So I would like to use the hardwareserial libery code (which is already used there) so i could first figure out whats going on exactly.
    But the problem is I do not get any output at the uart.
    code i want to execute in usb_dev.c so I can make my research:
    #if 1
                    serial_print("Desc found, ");
                    serial_phex32((uint32_t)data);
                    serial_print(",");
                    serial_phex16(datalen);
                    serial_print(",");
                    serial_phex(data[0]);
                    serial_phex(data[1]);
                    serial_phex(data[2]);
                    serial_phex(data[3]);
                    serial_phex(data[4]);
                    serial_phex(data[5]);
                    serial_print("\n");
    I use a ftdi board to get the serial communication to a picocom console. And its working if I do e.g. serial1.print('hello world'); but nothing from inside the usb_dev.c
    Maybe someone can tell me please what I am doing wrong?
Tags for this Thread
