Hi all,
I am having problems with a Teensy 3.1 board. I am using Arduino 1.0.6 and Teensyduino 1.20
When I connect the board to a PC with the loaded code and send UDP messages to the board, I am seeing UDP messages from the board stop and I suspect the processor is locked up. I The board sends UDP messages periodically, I would say around every 30-50 ms.
A reset of the processor (using the reset pad on the bottom) resolves the issue.
I have seen a lock-up problem with an Etherten board as well - I am thinking they may be related: http://forum.freetronics.com/viewtopic.php?f=4&t=6185.
Any thoughts?
Thanks,
Jeremy
Any thoughts?
Thanks,
Jeremy
