Page 1 of 15 1 2 3 11 ... LastLast
Results 1 to 25 of 375
Thread: Teensy-LC Beta Testing
    25,066
    Please use this thread for reporting successes, failures, and any patches or fixes discovered in beta testing Teensy-LC. For general discussion (anything that isn't a specific technical report or issue), please post on the main Teensy-LC announcement.
    Before soldering pins or wires, please test your Teensy-LC to verify it can upload code and print to the Arduino Serial Monitor.
    Often hardware product beta tests are done under nondisclosure agreements. Arduino does this for their new products. For Teensy-LC, we're trying it fully open in public view. Please use good judgement when choosing language to discuss bugs, especially issues likely to be fully resolved before we officially release Teensy-LC in March.
    EDIT: Version 1.21 is officially released.
    Many libraries have already been ported/patched. Please use the copies from the installers above, not copies from the website.
    Here's my testing list for Teensy-LC. As more testing is done, and as anyone suggests more things in need of testing, this message will be edited to update the list.
    digitalWrite                    ok
    digitalRead                     ok
    pinMode INPUT                   ok
    pinMode INPUT_PULLUP            ok
    pinMode OUTPUT                  ok
    analogRead(num)                 ok
    analogRead(A*)                  ok
    analogRead(38) temperature      ok
    analogRead(40) bandgap ref      ok
    analogRead noise level            - #221
    analogReference INTERNAL        ok
    analogReference EXTERNAL        ok
    analogReadResolution            ok
    analogWrite                     ok
    analogWriteResolution           ok
    analogWriteFrequency            ok
    analogWrite DAC                 ok
    IntervalTimer                   ok
    tone, noTone                    ok
    delay                           ok
    delayMicroseconds               ok
    millis                          ok
    micros                          ok
    elapsedMillis                   ok
    elapsedMicros                   ok
    attachInterrupt                 ok
    pulseIn                         ok - but requires pinMode - msg #53
    shiftIn
    shiftOut
    Serial1                         ok
    Serial2                         ok
    Serial3                         ok
    Serial1.transmitterEnable(pin)  ok
    Serial2.transmitterEnable(pin)  ok
    Serial3.transmitterEnable(pin)  ok
    touchRead                       ok
    DMAChannel                      ? - initial test look good - needs a lot more testing
    AVR emu: PORT                   ok
    AVR emu: PIN                    ok
    AVR emu: DDR                    ok
    AVR emu: SPI registers          quick test looks good
    AVR emu: SREG
    AVR emu: EIMSK
    AVR eeprom_read_byte            ok  (bootloader tries not to erase the EEPROM data)
    AVR eeprom_read_word                 possible issue with interrupts, msg 100-102
    AVR eeprom_read_dword
    AVR eeprom_read_block
    AVR eeprom_write_byte           ok
    AVR eeprom_write_word
    AVR eeprom_write_dword
    AVR eeprom_write_block
    portOutputRegister
    portInputRegister
    portModeRegister
    pgm_read_byte
    pgm_read_word
    pgm_read_dword                    -- see #139
    random
    (crash during auto-reboot)      -- #206
    (pauses during upload)          -- #221
    Keyboard.print                  ok
    Mouse.move                      ok
    usbMIDI.sendNoteOn
    Serial.print (USB Serial)       ok
    Serial.print (USB HID)          ok
    Wire                            ok  (tested with SSD1306 display)
    Wire slave mode                 ok
    Wire1
    i2c_t3                            -- #195, #204
    SPI                             ok
    SPI1                               - see #171
    SPI.setCLK(14)                  fail - see #258-260
    SPI.setMISO()
    SPI.setMOSI()
    SD                              ok - listfiles tested
    Ethernet W5100 chip             ok - Webclient and UdpNtpClient tested
    Ethernet W5200 chip             ok - Webclient and UdpNtpClient tested
    EEPROM
    Firmata                         ok - tested StandardFirmata with firmata_test, quick test only
    LiquidCrystal
    LiquidCrystalFast
    Servo                           ok - msg #53
    Encoder                         ok - TwoKnobs tested
    Keypad                          ok - HelloKeypad & MultiKey tested
    SoftwareSerial                  works only if pins are a hardware serial port
    Stepper                         ok
    PS2Keyboard                     ok
    OneWire                         ok - temperature example tested
    IRremote                        ok
    TinyGPS                         ok - needed updated to version 13, from Mikal Hart's website
    Bounce                          ok
    AccelStepper
    SoftPWM                         ok
    ShiftPWM                        fail - doesn't compile, needs porting
    Time                            looks good - still need to test GPS & NTP sync examples
    TimeAlarms                      ok
    Metro                           ok
    TimerOne                        ok
    TimerThree                      ok
    FreqMeasure                     ok
    FreqCount                       ok
    NeoPixel                        ok
    ILI9341_t3                      fail - depends on Teensy 3.x DSPI registers
    OctoWS2811                      fail - requires Teensy 3.x DMA - examples use too much RAM
    Audio                           fail - depends on Cortex-M4 instructions
    FTOLED
    Adafruit_CC3000                 ok - buildtest (with SSID+pass) tested
    Adafruit_ILI9340                ok
    Adafruit_ILI9341                ok
    Adafruit_nRF8001
    Adafruit_RA8875                 ok - ran textmode and ts_calibration
    Adafruit_SSD1306 I2C 128x32     ok
    Adafruit_SSD1306 I2C 128x64
    Adafruit_SSD1306 SPI 128x32     ok
    Adafruit_SSD1306 SPI 128x64
    Adafruit_ST7735                 ok?
    Adafruit_STMPE610
    Adafruit_VS1053                 fail - works with 24 MHz, fails with 48 MHz
    AltSoftSerial                   fail - needs timer defs
    Artnet                          ok - #200
    CapacitiveSensor                fail - needs I/O register defs
    DmxSimple                       fail - depends on DWT timer, not present on Cortex-M0+
    DogLcd                          ok
    DS1307RTC                       ok
    Entropy                         ok - msg #53
    FastLED                           - looking good, lib updated needed in Teensyduino, #220, #212
    FlexiTimer2                     ok
    FrequencyTimer2                 fail - used CMT timer, not present in this chip
    ks0108                          fail - this library needs C++ boolean = bool update
    LedControl                      ok
    LedDisplay                      fail - most works, but writeCharacters fails (also on Teensy 3.1)
    MIDI
    MsTimer2                        ok
    NewPing
    OSC
    Ping                            ok
    PulsePosition                   ok
    PWMServo                        fail - needs timer defs
    RadioHead
    SPIFlash
    ST7565                          ok
    Tlc5940                         fail - needs defs for hardware
    UTFT                            fail - needs cpu define, maybe other work?
    UTouch
    VirtualWire
    x10
    OpenGLCD                        ok
    SdFat
    ledRings                        ok - msg #53
    FastCRC
    Other stuff to investigate:
    SoftPWM's SoftPWM_LEDHead_Random_Blink crashes with unsupported pins - why?  Is this simply a bug in SoftPWM?
    Does SPI.transfer(buffer, size) work?  Does it achieve 100% SPI bus utilization?
    IRremote gets messed up by Robot libraries - time for a patch in the java code to ignore them!
    25,066
    PS2Keyboard has been fixed.
    https://github.com/PaulStoffregen/PS2Keyboard
    25,066
    2,655
    Wow, I can't believe how much stuff you've already tested!
    The DAC register structure looks pretty close. Here's a self-contained proof-of-concept (virtual testing til the LC arrives) of DAC, untested but compiles
    // dac hack til in core
    #define VREF 3.3
    #define DAC0_DAT0L      (*(volatile uint8_t  *)0x4003F000)
    #define DAC0_C0         (*(volatile uint8_t  *)0x4003F021)
    #define DAC_C0_DACEN            0x80
    #define DAC_C0_DACRFS           0x40
    void writeDAC0(int val)
    	int analog_reference_internal = 0;
            uint8_t res = 12;   // analog_write_res;
            if (res < 12) {
                val <<= 12 - res;
            } else if (res > 12) {
                val >>= res - 12;
        SIM_SCGC6 |= 0x80000000;
        if (analog_reference_internal) {
            DAC0_C0 = DAC_C0_DACEN;  // 1.2V ref is DACREF_1
            DAC0_C0 = DAC_C0_DACEN | DAC_C0_DACRFS; // 3.3V VDDA is DACREF_2
        if (val < 0) val = 0;  // TODO: saturate instruction?
        else if (val > 4095) val = 4095;
        *(int16_t *)&(DAC0_DAT0L) = val;
    	  analogReadResolution(16);
    	  analogReadAveraging(32);
      int i, sensorValue,k;
      float v;
      char str[80];
      for (i=0; i< 4096; i+=40) {
        writeDAC0(i);
        sensorValue = analogRead(A0);
        v= VREF * sensorValue/65536.;
        k = sensorValue>>4;
        sprintf(str,"%d %.3f %d %d",i,v,k,sensorValue);
        Serial.println(str);
    Germany
    9,308
    My board arrives on friday, i can test with real servomotors, i2c and some other things..
    25,066
    I've added the definitions for DMA and the DAC.
    https://github.com/PaulStoffregen/co...dd0022111246d2
    Much work remains to be done porting DMAChannel.h
    25,066
    25,066
    I added dummy RTC functions, since we're not supporting the useless on-chip RTC.
    Time & TimeAlarms seem to work, but I only tested the "serial" examples. The NTP and GPS sync should probably still be tested.
    25,066
    2,655
    curious why you are using volatile uint16_t * e.g.
    #define DMA_SAR0 (*(volatile uint16_t *)0x40008100)
    older kinetis.h entries were
    #define DMA_TCD2_SADDR (*(volatile const void * volatile *)0x40009040)
    25,066
    I tested many more of the library and updated the list for which work and which fail.
    25,066
    Opps, that was a silly mistake. Good catch, Thanks!
    https://github.com/PaulStoffregen/co...6268cec3a9e630
    Porting the DMA stuff is probably going to be a big job. My hope is to switch most of the DMA-based libraries from writing the TCD structure to calling the hardware-neutral functions of DMAChannel.h. That's why I designed DMAChannel months ago... so when this day came, we could have a nice API that doesn't require putting hardware registers into libraries. Well, I guess I'd imagined getting OctoWS2811 and parts of Audio switched over by now, but then everything always takes much longer than anticipated!
    Anyway, my plan for next week is going to be working on DMAChannel.h and Audio's ADC and DAC objects.
    First, I want to get IRremote working, and take a shot at fixing the serial monitor bugs I added in 1.21-test2. It'd be really nice to get 1.21-test4 out this weekend, with all these fixes.
    2,655
    I think I will be able to run NTP/GPS crystal checks this evening I'm assuming LC is using same crystal as other teensy's, 15 ppm NDK NX3225SA-16, and might get to the Time library as well ...
    2,655
    This morning I looked at IRremote (having done proof-of-concepts on maple and early DUE), looks like one could use two FTM/TPM channels, but i'll leave it to you!
    25,066
    We're actually switching to an Epson crystal that's rated for 18 ppm, but with a wider temperature range.
    2,655
    Re: PulsePosition fails -- locks up
    looking at ref manuals, looks like to clear TPM/FTM TOF on LC, you have to write a 1. on teensy 3's, just need to read SC register.
    that will be important if you use FTM for IRremote
    Feb 2013
    179
    Paul, is it this one? http://www.digikey.com/product-detai...6CT-ND/1825448
    I kind of doubt it, but I would be tickled if it were (that's the one I use on my custom PCB).
    Senior Member duff's Avatar
    Las Vegas
    1,027
    Ok this is follow up to the github pull request which I thought would be better to be discussed here. Basically talking about the startup code and TeensyLC PLL.
    Is the PLL configured and running at 16,8,4,2 MHz, I don't see in the mk20dx128.c startup code where the PLL is activated at those F_CPU's? It looks like the clocks are setup the same for the Teensy3.x and TeensyLC at those speeds. Or is this something that has not been tested yet, it seems that only 24, 48 MHz has only been tested? If not I'm willing to tackle this.
    25,066
    Quote Originally Posted by duff View Post
    Exactly, only 24 & 48 MHz have been tested so far. Absolutely no work has been done with any other speed. It's be great if you could look into those. I won't be able to do much anytime soon, since I'm focused on getting functionality like IRremote and DMAChannel.h ported, and fixing bugs like the serial monitor issue.
    Las Vegas
    1,027
    ok, on it
    2,655
    teensy LC arrives. plugged it in and is happily blinking ... onward!
    WARNING beta teensy LC test results 1.0.6/1.21-test3
    here are some results for speedTest (teensy 3.1 3.0 LC)
    https://github.com/manitou48/teensy3...ter/LCperf.txt
    NOTE: LC does not have hardware divide
    power with hacked USB cable LED off/on
    LC 17.38/20.22ma @ 48mhz (hacked USB cable), 14.64/17.5 @ 24mhz (beta: bootloader at full power)
    teensy 3.0 @96mhz 24.36/27.3 ma @48mhz 20.42/23.38m
    teensy 3.1 @96mhz 38.1/41.1 2/4/15 @48mhz 28.35/31.29
    duff's low power lib did not compile (TBD)
    check LC crystal drift against NTP stratum 0 server: 13 ppm
    also checked crystal with GPS pps to LC: 13ppm
    also see https://github.com/manitou48/crystal...r/crystals.txt
    LC unconnected SPI speed (1000 byte transfer)
    10mbs (megabits/sec) at default speed and transaction request of 24000000 and 12000000
    3.5mbs at 4000000
    (things to await/try SPI + FIFO, SPI + DMA, is SPI1 faster ?)
    simple DMA sketch for memcpy32() and memset32() seemed to have worked.
    FFT 1000 doubles -- not enough RAM
    LC beta computational performance numbers at
    https://github.com/manitou48/DUEZoo/...aster/perf.txt
    includes fibonacci, linpack(mflops), aes, md5
    i was able to read teensy MAC address MAC: 04:E9:E5:00:07: D9
    if I click "no scroll" on monitor window in fast scrolling data, IDE locks up-- have to ctrl-z kill it...
    .... more to come
    Las Vegas
    1,027
    I have hacked copy that complies but the digital pins and tsi need to be worked on but from what I've looked at so far I think going into LLS sleep (deepSleep) should be the same but I can't say for sure yet, no board until tomorrow.
    2,655
    duff, do you have a github site? I often worry I don't have the latest zip file ... thanks
    25,066
    I should mention some bad news on beta testing low power. The bootloader chip on these first 10 beta boards remains in full speed mode 100% of the time. I'm going to enable sleep detection, like the Mini54 does on Teensy 3.1, but that feature didn't make these first 10 beta boards.
    When posting current measurements, please keep in mind we're doing this beta test in public view. Power benchmarks done now, on these 10 beta test boards, will not be representative of what people will see in the final product.
