Is there a 1-Wire Device Limitation on MicroLan with OneWire library?
cfo215
New member
I have twenty Maxim DS2406 Dual Addressable Switches (TO-92 package which only has PIO-A) on a MicroLan. I can only see 8 of them at a time. My engineer put a scope on the line and "the signaling looks good". I'm a programmer myself, so I have to take his word on it....
Is there a limitation on the number of connected devices that I connect to the MicroLan? I keep reaching a limit of 8 devices sensed.
My simple code follows. My device is an Arduino Mega2560. I'm using Pin 10 to communicate with the MicroLan, and there is nothing else connected to the Mega.
// This sketch looks for 1-wire devices and
// prints their addresses (serial number) to
// the UART, in a format that is useful in Arduino sketches
// Tutorial:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
#include <OneWire.h>
OneWire  ds(10);  // Connect your 1-wire device to pin 10
void setup(void) {
//  discoverOneWireDevices();
void discoverOneWireDevices(void) {
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  Serial.print("Looking for DS2406 1-Wire devices...\n\r");
  ds.target_search(12);
  while(ds.search(addr)) {
    Serial.print("\n\rFound \'1-Wire\' device with address:\n\r");
    for( i = 0; i < 8; i++) {
      Serial.print("0x");
      if (addr[i] < 16) {
        Serial.print('0');
      Serial.print(addr[i], HEX);
      if (i < 7) {
        Serial.print(", ");
    if ( OneWire::crc8( addr, 7) != addr[7]) {
        Serial.print("CRC is not valid!\n");
        return;
  Serial.print("\n\r\n\rThat's it.\r\n");
  ds.reset_search();
  return;
// added 2/5/2014
void discoverOneWireDevices_v2(void) {
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  Serial.println("Reseting the 1-Wire MicroLan");
  if(ds.reset()) {
    Serial.println("Looking for DS2406 1-Wire devices...");
    // Look for the next device via ds.search(addr).
    // Returns 1 if a new address has been returned.
    // Loops until you have retrieved all of them.
    // see Notes in OneWire.h for more info.
      Serial.println("\n\rFound \'1-Wire\' device with address:");
        Serial.print("0x");
        if (addr[i] < 16) {
          Serial.print('0');
        if (i < 7) {
          Serial.print(", ");
          return;
    // Clear the search state so that if will start from the beginning again.
    ds.reset_search();
    return;
    Serial.println("No 1-Wire device or the bus is shorted or otherwise held low for more than 250uS.");
    return;
void loop(void) {
    discoverOneWireDevices_v2();
My teensynet project uses the 1-wire library, and I've had up to 36 devices (DS18B20, DS2406, etc) on the microlan with no problems.
