Hi guys,
I have lying around some ST7735 TFTs (160x128), some Teensys 3.1 and one Teensy audio adaptor boad.
I've been trying to build up some kind of realtime audio spectrum view. Like this:
With less resolution and acuracy, but you get the idea.
This is the TFT module:
I'm stuck trying to drive the TFT display (using hardware SPI) when the Teensy has the companion audio board attached.
I can't find the correct pins configuration for the TFT while using the audio board so it doesn't interfere.
So far I've know there's only one SPI port in the teensy 3.1 with some alternate pins avalaible (and a lot of CS).
I think that audio board do not use SPI apart from SD socket and the W25Q128FV memory. So I've tried without luck the pins (among others) 14 (sck) , 7(mosi) , 6(cs), 15(dc) and 4(rst).
I'm sure I am doing something terribly wrong. Any enlightenment will be greatly apreciated.
Luis M. Ruiz
// Default pins in the ST7735 Examples.
// No audio data in myFFT.read(). <------------------
#define sclk 13 // SCLK can also use pin 14
#define mosi 11 // MOSI can also use pin 7
#define cs 10 // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
#define dc 9 // but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
#define rst 8 // RST can use any pin
/* Alternate Pins. I think are correct but the display don't work with this ones.
#define sclk 14 //SCLK can also use pin 14+
#define mosi 7 //MOSI can also use pin 7
#define cs 2 //CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
#define dc 6 //but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
#define rst 8 //RST can use any pin
#define DISPLAY_WIDTH 128
#define DISPLAY_HEIGHT 160
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
Adafruit_ST7735 display = Adafruit_ST7735(cs, dc, rst);
AudioInputI2S audioInput; // audio shield: mic or line-in
AudioAnalyzeFFT256 myFFT;
AudioConnection patchCord1(audioInput, myFFT);
display.initR(INITR_REDTAB);
display.fillScreen(ST7735_BLACK);
AudioMemory(12);
audioShield.enable();
audioShield.inputSelect(AUDIO_INPUT_MIC);
myFFT.windowFunction(AudioWindowHanning256);
void loop (){
float n;
int i;
if (myFFT.available())
for (i=1; i<128; i++) {
n = myFFT.read(i);
display.drawFastVLine(i,0,DISPLAY_HEIGHT,ST7735_BLACK);
display.drawFastVLine(i,0,n*DISPLAY_HEIGHT,ST7735_WHITE);
Luis M. Ruiz
