Accessing Comparator Hangs Serial on Teensy 3.1
tlb
I am trying to use the comparator on Teensy3.1. I am talking to Teensy over USBSerial. If I do any accesses to the comparator, Serial will not initiate, even if the comparator code is after the Serial.begin(9600).
The program works fine, and then if I add the line:
uint8_t testVar;
testVar=CMP0_SCR;
serial will not initiate. Any ideas? I have additional comparator code which also hangs the system, but even this minimal read does it.
Thanks much,
TLB
Almost everything in the chip defaults to powered down. If you try to use something without first turning it on, you get a hard fault.
