Hey all... round two of questions
Here's a synopsis of my design:
I'm creating a MIDI controllable guitar pedal. Ideally, I'll have my void loop running as quickly as possible to keep up with / process any incoming MIDI signals (program change and CC messages). I would like to have visual feedback on my LCD display as the program is running (for example, if there are no incoming MIDI messages it will show the currently selected preset, if there is a program change the number on the display will update accordingly). Later on, I'll be implementing a rotary encoder to scroll through a menu to change any options I need to.
The first (expected) problem that arrises is that my display will constantly refresh with the loop. I am hesitant to add a delay inside any of the TFT functions because I don't want to slow down the MIDI read process. I've tried a couple iterations of while and do while loops to try and solve the problem but to no avail. My current code is below(I do have a delay in the main loop just so I don't die from the strobe effect). In essence, I want the MIDI.read() function to constantly be waiting for an input while I have a steady output to my display.
My intuition tells me that interrupts will have to be implemented somehow, but I'm not sure quite how to start with such an endeavour. Any guidance would be heartily appreciated!
#include "SPI.h"
#include "ILI9341_t3.h"
#include <EEPROM.h>
#include <MIDI.h>
#include <midi_Defs.h>
#include <midi_Message.h>
#include <midi_Namespace.h>
#include <midi_Settings.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial3, MIDI); // create an instance of MIDI using hardware serial serial 3 port
struct Preset{
byte lOhm;
byte lWet;
byte rOhm;
byte rWet;
// MIDI Function Prototypes
void PresetStore(struct Preset pToWrite, int presetNum);
struct Preset PresetRead(int presetNum);
void GlobalSettings();
// For the Adafruit shield, these are the default.
#define TFT_DC 9
#define TFT_CS 10
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
// If using the breakout, change pins as desired
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
// MIDI Setup
MIDI.setHandleProgramChange(DealWithProgramChange);
MIDI.setHandleControlChange(DealWithControlChange);
MIDI.begin(MIDI_CHANNEL_OMNI);
// ILI9341 Setup
Serial.println("ILI9341 Test!");
tft.begin();
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(ILI9341_RDMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDPIXFMT);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDIMGFMT);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDSELFDIAG);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
Serial.println(F("Benchmark Time (microseconds)"));
Serial.print(F("Screen fill "));
Serial.println(testFillScreen());
// MAIN LOOP
void loop(void) {
while(MIDI.read() == 0)
presetScreen();
delay(10000);
// DISPLAY FUNCTIONS
unsigned long testFillScreen() {
unsigned long start = micros();
tft.fillScreen(ILI9341_RED);
tft.fillScreen(ILI9341_GREEN);
tft.fillScreen(ILI9341_BLUE);
return micros() - start;
unsigned long testText() {
tft.setCursor(0, 0);
tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2);
tft.println(1234.56);
tft.setTextColor(ILI9341_RED); tft.setTextSize(3);
tft.println(0xDEADBEEF, HEX);
tft.println();
tft.setTextColor(ILI9341_GREEN);
tft.setTextSize(5);
tft.println("Groop");
tft.setTextSize(2);
tft.println("I implore thee,");
tft.setTextSize(1);
tft.println("my foonting turlingdromes.");
tft.println("And hooptiously drangle me");
tft.println("with crinkly bindlewurdles,");
tft.println("Or I will rend thee");
tft.println("in the gobberwarts");
tft.println("with my blurglecruncheon,");
tft.println("see if I don't!");
unsigned long presetScreen(){
tft.fillScreen(0xD6EBFF);
tft.setCursor(20, 25);;
tft.setRotation(1);
tft.setTextColor(ILI9341_BLUE); tft.setTextSize(7);
tft.println("Preset");
tft.setCursor(197, 100);
tft.setTextSize(6);
tft.println("xx");
// MIDI FUNCTIONALITY
// Program Change Handler
void DealWithProgramChange(byte channel, byte number)
int ch, bank;
ch = MIDI.getChannel();
bank = MIDI.getData1();
Serial.println(String("Program change") + bank + "on channel" + ch + "received!");
// Control Change Handler
void DealWithControlChange(byte channel, byte number, byte value)
int ch, param, ccValue;
param = MIDI.getData1();
ccValue = MIDI.getData2();
Serial.println(String("Control change param of ") + param + "on channel" + ch + "with value of" + ccValue + "received!");
