/* This code is free to use */
/* Kire Pudsje, Feb. 2015 */
#include "arm_math.h"
#define FFTSIZE 1024
int16_t s1[FFTSIZE], s2[FFTSIZE];
int16_t fft_buf[FFTSIZE * 2];
int32_t ifft_buf[FFTSIZE * 2];
arm_cfft_radix4_instance_q15 fft_inst;
arm_cfft_radix4_instance_q31 ifft_inst;
arm_cfft_radix4_init_q15(&fft_inst, FFTSIZE, 0, 1);
arm_cfft_radix4_init_q31(&ifft_inst, FFTSIZE, 1, 1);
// generate two signals with random data, s2 is delayed s1
unsigned offset = random(FFTSIZE / 4);
for (unsigned i = 0; i < FFTSIZE + offset; i++) {
int16_t val = ((int16_t) random(65536));
if (i < FFTSIZE)
s1[i] = val;
if (i > offset)
s2[i - offset] = val;
// Copy samples interleaved to FFT buffer s1 in real part, s2 in complex part
// ie. fftbuf = s1 + j * s2
for (int i = 0; i < FFTSIZE; i++)
((int32_t *)fft_buf)[i] = (s2[i] << 16) | s1[i];
elapsedMicros us; // start timing
// Perform FFT
arm_cfft_radix4_q15(&fft_inst, fft_buf);
// Untangle fft of both signals and calculate conj(fft(s1)) * fft(s2)
// Treat DC point special
int16_t fs1_re, fs1_im, fs2_re, fs2_im;
fs1_re = fft_buf[0]; // fs1_im = 0
fs2_re = fft_buf[0]; // fs2_im = 0
ifft_buf[0] = fs1_re * fs2_re;
ifft_buf[1] = 0;
// Then handle most other points
int16_t *fft_fwd = fft_buf + 2;
int16_t *fft_rev = fft_buf + 2 * (FFTSIZE - 1);
for (size_t i = 2; i < FFTSIZE; i += 2, fft_fwd += 2, fft_rev -= 2) {
fs1_re = (fft_fwd[0] + fft_rev[0]) >> 1;
fs1_im = (fft_fwd[1] - fft_rev[1]) >> 1;
fs2_re = (fft_rev[1] + fft_fwd[1]) >> 1;
fs2_im = (fft_rev[0] - fft_fwd[0]) >> 1;
// calculate conj(fft(s1)) * fft(s2)
int32_t cfs1_fs2_re = (fs1_re * fs2_re + fs1_im * fs2_im);
int32_t cfs1_fs2_im = (fs1_re * fs2_im - fs1_im * fs2_re);
ifft_buf[i] = ifft_buf[2 * FFTSIZE - i] = cfs1_fs2_re;
ifft_buf[i + 1] = cfs1_fs2_im;
ifft_buf[2 * FFTSIZE - i + 1] = -cfs1_fs2_im;
// Finally handle Nyquist point
fs1_re = fft_fwd[0]; // fs1_im = 0
fs2_re = fft_fwd[1]; // fs2_im = 0
ifft_buf[FFTSIZE] = fs1_re * fs2_re;
ifft_buf[FFTSIZE + 1] = 0;
// Perform inverse FFT
arm_cfft_radix4_q31(&ifft_inst, ifft_buf);
uint32_t duration = us; // end of timing
// The output data is in every second element of ifft_buf
// As an example, find the cross-cor peak
int peak_offset = 0;
int32_t peak_value = ifft_buf[0];
for (size_t i = 1, j = 2; i < FFTSIZE; i++, j += 2) {
if (ifft_buf[j] > peak_value) {
peak_value = ifft_buf[j];
peak_offset = i;
if (peak_offset > FFTSIZE / 2)
peak_offset -= FFTSIZE;
Serial.print("Generated offset: ");
Serial.println(offset);
Serial.print("Calculated offset: ");
Serial.println(-peak_offset); // delay implies negative
Serial.print("It took ");
Serial.print(duration);
Serial.println(" us\n");
