PaulStoffregen
Odd (to me) that Windows isn't the common machine
Most of the Arduino devs use Macs. I use Linux, as do many others. Windows seems to be the least used OS for actual development of the Arduino software.
But my guess is that it is the most used OS for Arduino users. Personally I think they need to eat their own dog food.Most of the Arduino devs use Macs. I use Linux, as do many others. Windows seems to be the least used OS for actual development of the Arduino software.
Post #984 in the long Audio Library thread might be worth looking at. BTW: is there an easy way to post a pointer to a post?
Do you have a sticky thread on current Beta location files?
[edit] still puzzled how I managed to get three machines to the exact same failure point . . . must have been the IDE installer with other versions - always in DOCUMENTS.
C:\arduino-1.6.0/hardware/tools/arm/bin/arm-none-eabi-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 C:\Users\Kurt\AppData\Local\Temp\build1262815931451805609.tmp/FFT.cpp.elf C:\Users\Kurt\AppData\Local\Temp\build1262815931451805609.tmp/FFT.cpp.eep
C:\arduino-1.6.0/hardware/tools/arm/bin/arm-none-eabi-objcopy -O ihex -R .eeprom C:\Users\Kurt\AppData\Local\Temp\build1262815931451805609.tmp/FFT.cpp.elf C:\Users\Kurt\AppData\Local\Temp\build1262815931451805609.tmp/FFT.cpp.hex
Sketch uses 93,168 bytes (35%) of program storage space. Maximum is 262,144 bytes.
-IC:\arduino-1.6.0\hardware\teensy\avr\libraries\SD -IC:\Users\Kurt\Documents\Arduino\libraries\Audio\utility C:\Users\Kurt\Documents\Arduino\libraries\Audio\analyze_fft1024.cpp -o C:\Users\Kurt\AppData\Local\Temp\build1262815931451805609.tmp\Audio\analyze_fft1024.cpp.o
C:\Users\Kurt\AppData\Local\Temp\ccVD0NN8.s: Assembler messages:
C:\Users\Kurt\AppData\Local\Temp\ccVD0NN8.s:339: Error: selected processor does not support Thumb mode `smuad r6,r6,r6'
Error compiling.
Note: I tried compiling it on my Win 7 machine and it compiled, but with reasonably different sizes than Pauls...
I'm mystified by this too, and I *really* want to get to the bottom of it. I just don't know how.
Maybe I could prepare a special arduino-core.jar file you could put into the "lib" folder, that would print a lot of extra info when you run the Arduino-debug program. Are those 3 machines still doing this? Any chance you could give that a try?
Sketch uses 91,052 bytes (34%) of program storage space. Maximum is 262,144 bytes.
Global variables use 13,404 bytes (20%) of dynamic memory, leaving 52,132 bytes for local variables. Maximum is 65,536 bytes.
I:\Teensy16/hardware/tools/teensy_post_compile -file=FFT.cpp -path=C:\Users\Tim\AppData\Local\Temp\build516914291992542668.tmp -tools=I:\Teensy16/hardware/tools -board=TEENSY31 -reboot
Opening Teensy Loader...
// Connect either the live input or synthesized sine wave
//AudioConnection patchCord1(audioInput, 0, myFFT, 0);
AudioConnection patchCord1(sinewave, 0, myFFT, 0);
WARNING: library Audio claims to run on [sam] architecture(s) and may be incompatible with your current board which runs on [avr] architecture(s).
I:\Teensy16/hardware/tools/arm/bin/arm-none-eabi-g++ -c -g -Os -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=121 -DARDUINO=10600 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Users\Tim\Documents\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Users\Tim\Documents\Arduino\libraries\Audio\src -IC:\Users\Tim\Documents\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Users\Tim\Documents\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Users\Tim\Documents\Arduino\libraries\SD\src C:\Users\Tim\AppData\Local\Temp\build580909417594465133.tmp\T_ADCLibUpd_101_25532.cpp -o C:\Users\Tim\AppData\Local\Temp\build580909417594465133.tmp\T_ADCLibUpd_101_25532.cpp.o
T_ADCLibUpd_101_25532.ino:26:17: fatal error: ADC.h: No such file or directory
compilation terminated.
Error compiling.
