defragster
Senior Member+
[ edit : Happens on my Win7 and two less used Win8.1 machines ]
SPOILER ALERT from post #75:
Due Diligence - before I posted the following about Forum Code I saw this FFT example: "C:\Users\Tim\Documents\Arduino\hardware\teensy\avr\libraries\Audio\examples\Analysis\FFT\FFT.ino"
Same setup as below - same Error:
Looking to understand FFT and see a working example I pulled code (copy paste to IDE) from https://forum.pjrc.com/threads/24793-Audio-Library/page19: [03-25-2014, 09:30 AM]
Maybe the library changed in 11 months - maybe this is a problem with error messages?
If there are similar FFT samples I hope to find them . . . these were first up. [No AUDIO board and hoping to use Synthetic Sound source.]
What is Teensy_reboot.exe noted below?
Why does it see my SAM "Board: Teensy 3.1" as AVR?
I found this example from BING Does Google or Bing index this site for better searching? The native search box doesn't hit well on complex searches.
https://forum.pjrc.com/threads/24793-Audio-Library?p=44615&viewfull=1#post44615
and
https://forum.pjrc.com/threads/24793-Audio-Library?p=44643&viewfull=1#post44643
Using Teensy 3.1 and TeensyD 1.21-B6 with IDE 1.6 beta on Win7.
ON Latter example msg:#456 First time CPU was spun up and TaskMgr showed a Teensy_reboot.exe? The compile never completed. I shut it and IDE down and restarted and the _Reboot.exe didn't return, but that compile didn't complete just showed this and a waiting 'compiling bar under 50%'
Compiling the first linked example msg:#453 it stopped on error saying that:
You must create a clean sketchbook folder which does NOT contain a copy of the Arduino software.
I dropped my sketchbook folder into my Arduino folder and this was fine. But when I told the IDE where my folder was - I directed it to the Arduino root directory - because then I saw more sample sketches - but that was BAD because the IDE re-included everything it saw in that directory.
WARNING: library Audio claims to run on [sam] architecture(s) and may be incompatible with your current board which runs on [avr] architecture(s).
In file included from C:\Users\Tim\Documents\Arduino\libraries\Audio\src/Audio.h:16:0,
from FFT.ino:14:
Error compiling.
My file "...\Documents\Arduino\libraries\Audio\src/Audio.h:16:0":#include "DAC.h"
and
from T_FFT_456_24793.ino:1:
Build options changed, rebuilding all
from T_FFT_453_24793.ino:1:
Error compiling.
