Results 1 to 5 of 5
Thread: More MINI54 Trouble
    More MINI54 Trouble
    After following all advice on board design for a custom Teensy board and using exactly the same parts
    used on the teensy, I have trouble getting my Custom Board running.
    If I press the PROG button, the Teensy Loader indeed uploads the code, but afterwards the code doesn't
    seem to run (LED Blink Example). I have verified the connections and everything seems to be fine.
    The only difference in my circuit is that I supply the 3.3V externally from a Bench Power Supply and
    that VBUS is not connected (which means only GND, D+, D- are connected).
    What I cannot explain: PROG seems to trigger firmware upload, but after code upload no USB device
    is being enumerated.
Name:	Bildschirmfoto 2015-02-26 um 13.00.19.jpg
    Crystal is 8pF, Inductors are 10uH. VDD = 3.3V
    Crystal Symbol looks wrong on the Schematic, but all connections are good.
    The Capacitors and the Series Resistor is not assembled on the board.
    Looks like it could be it. Suddenly I got a weird effect: Both MK20 on 2 different boards assembled by 2 different people get suddenly
    hot whenever powered is applied. There are no shorts on the board and all solder points have been checked under the microscope.
    Did anyone have something like this before?
    23,015
    Just a couple days ago there was mysterious, still-unresolved heating of the chip on Teensy-LC when a certain OLED display was used.
    Amazing IR camera images were posted....
    Senior Member Constantin's Avatar
    In the yard with a 17' Dia. Ferris Wheel
    1,408
    Don't discount the possibility of the OLED being at fault, in some strange way.
    I.e. the Teensy having to sink an inordinate amount of current, etc. that a UNO can tolerate more easily. I remember being rather amazed re: all the ways that a Uno can be fried by looking over the Ruggeduino specifications and discussion of their protection mechanisms.
