Results 1 to 18 of 18
Thread: Plans for Teensy 3.1 with MINI54TAN?
    Oct 2014
    5
    What are the plans for the Teensy 3.1 since the MINI54TAN chip will be obsolete soon?
    22,079
    There's actually 2 plans...
    We currently have a large number of the MINI54TAN parts, enough to last about 6 months.
    Short-term, I've got some of the newer MINI54TDE parts here for testing. After Teensy-LC is released, a bootloader upgrade to fix the pin 33 issue is pretty high on my priority list. I'm going to test with both 'TAN and 'TDE, so we'll be able to use either.
    Longer-term, the plan is to switch Teensy 3.1 to the KL02 part which is on Teensy-LC.
    Jun 2013
    So. Calif
    2,828
    Request: New bootloader have some means to optionally not erase the top n sectors.
    @PaulStoffregen: I'm working on rev 3 of a prototype that has a footprint for the Teensy Loader MINI54LAN chip. I don't see any major pinout differences between the MINI54LAN and MINI54LDE.
    Do you plan to offer the MINI54LDE with Teensy Loader installed once your stock of MINI54LAN is gone?
    The answer I received by email was "yes"
    22,079
    Yup, I've got some of the "DE" parts right here. I'll be testing with them when I work on the pin 33 issue.
    Feb 2013
    179
    Oof, first I'm hearing of this. Wonderful! Is the DE a drop-in replacement for those of us with custom boards?
    22,079
    The new DE parts are a drop-in replacement.
    Internally, the DE chip has some additional power saving modes and other minor changes, which is why I need to test carefully to make sure the next rev works on both AN and DE.
    Member mixania's Avatar
    Oct 2014
    New York, NY
    20
    What would be the benefits? I was thinking of getting the Teensy-LC but got the 3.1 instead since I wanted the full juice. The Teensy-LC's low cost concept certainly pays a toll on the processor specs.
    I hope something like the MINI54TDE won't be the sequel of Teensy's 3.1 processor. 24 MHz, no overlock? (seriously?). I certainly can't argue with the low power Cotex-M0 abilities thought, thats for sure.
    22,079
    I have no plans to ever make a Teensy where any Nuvoton part is the main chip you program.
    Oct 2012
    Portland OR
    689
    Quote Originally Posted by mixania View Post
    I believe the MINI54 device is used only for the bootloader on Teensy 3.0, 3.1 and LC; the previous MINI54TAN flavor is becoming obsolete so Paul's testing an updated version going forward- again, presumably just bootloader function.
    Oct 2014
    New York, NY
    20
    Quote Originally Posted by JBeale View Post
    I see, that solved my confusion
    MINI54TAN? "Mini Satan?"
    22,079
    LOL, yes!! Especially its low power features. Buggy and terribly difficult to use.
    Oct 2014
    New York, NY
    20
    I can trust more a statement from an actual engineer rather than some broucher braging about low-power features.
    When I wrote a DMA WS2812 driver for Raspberry Pi last year, I learned something very important: What it says in the programmer's manual, and what was actually put onto the chip, are often two different things!!!
    22,079
    Yup, that can be terribly frustrating.
    Nuvoton generally documents all their features, sometimes in broken English, and sometimes with very confusing wording. That's the easy part. The hard part is the errata, which they don't publish. I'm sure if they did, it would be much longer than the entire reference manual.
    The RasPi's PWM and DMA engines have the same problem, unpublished errata. It took me a while to figure out that the PWM engine needs to be "massaged" to operate like the manual says it should.
