Midi PCB
jjrh
I'm making a stab at building my first PCB using GEDA. It's a copy of the schematic PJRC posted https://www.pjrc.com/teensy/td_libs_MIDI_sch.gif
so I can start mucking around with the teensy audio board for synth stuff using my midi controller.
I was hoping someone could verify I didn't do anything grossly wrong before I ship it to get made.
https://github.com/jjrh/midi_shield is the github with all the project files and some renders of the board.
-jjrh.
Are you sure you want to connect the shield of MIDI-IN to ground?
Looks like you have traces that depend on connectivity across some large holes for the connectors, which don't have an annular ring. You might look into whether those connections will be made.
With diodes, it's common practice to add a mark on the silk screen layer to indicate the cathode side. While this doesn't affect the PCB traces at all, it is really helpful when you later solder the parts.
I thought the shield was supposed to be connected to ground?
Thanks, I'll look into it.
Good call didn't think of that!
Okay I made the suggested changes (I think) annular rings should be bigger. I removed the 'extra pins' connectors which just added complexity. I sent the midi in shield to NC.
I also fixed a issue where the pins to the teensy were connected that shouldn't have been.
Let me know if I missed anything! (you can compare https://github.com/jjrh/midi_shield/commit/44a67bb13a93c06c29cdebd2bd0c92d841744b79 for the PCB renders and https://github.com/jjrh/midi_shield/commit/32c77f1eb0964c927067037f4667cbb6881d92ec for the schematic)
Which Teensy is this for - a 5V one like Teensy 2.0 / Teensy++ 2.0 or a 3V3 one like Teensy 3.0/3.1/LC?
Going to be a teensy 3.1 (it's so I can do work with the audio shield)
I guess I should add room for the two resistors on the midi out.
Room for a dip switch might be cute.
Teensy 3.0: Use two 47 ohm resistors on MIDI OUT, with the pin 4 resistor to +3.3 volts. For MIDI IN, connect the 270 ohm resistor to +3.3 volts. (TODO: add a Teensy 3.0 specific schematic here)
are the two 47ohm resisters in parallel or series?
Is the midi in 270 ohm resister the one on pin4 of the PC900?
Okay updated the schematic to be for the 3.3v. (I assumed those resisters are in series)
Just thought I would say I successfully got the boards made from seeedstudio.
I had one mistake, the diode silkscreen (maybe also in the schematic? - I should check...) is backwards. I discovered this after spending more time than I would like to admit debugging the board.
At some point I'll fix this up.
I also should also put better labels on the pinout.
I can probably also pretty easily do the layout to be 5v or 3.3v.
Seeedstudio did the drill holes which I guess in the gerber file weren't all the way through the board.
I can probably condense everything further and use thinner traces.
Paul, if you see this feel free to update http://www.pjrc.com/teensy/td_libs_MIDI.html to include my schematic.
