Arduino 1.6.1 file extension for Linux oddity
linuxgeek
I downloaded and installed Arduino 1.6.1.
The downloaded file is Arduino-.1.6.1-linux64.tar.xz
WTH is ".xz" file extension?!
I guess everyone uses a gui that might try and figure out what type of file it is.
I figured, it's a download so it must be compressed (z usually denotes that), that would only make sense. gzip? No -- bzip2? No
It's just an uncompressed tar file. Strange.
Under unix you can type
file Arduino-.1.6.1-linux64.tar.xz
to see information about the file type, it does not look at the extension.
Also for untarring, you do not have to specify the compression, just do
tar -xvf file
x = extract
v = verbose (ie show files while untarring)
f = untar from file
xz is a "new" compression format based on LZMA. "tar -Jxvf <file>" is what you want. It's slowly replacing bzip2, which has a lower compression ratio and is also slower to decompress.
If you like command-line, there is atool which is a nice suite of tools, easier to use than raw tar. Just "aunpack <file>" to extract files. As a bonus, if the archive does not contain a single root directory, it'll make one so you won't ever pollute your working directory. There's a package available in most distributions (at least Ubuntu, Fedora and Arch).
Ahhh, ok. It was really hard to find any info on it. I must've done something stupid when I typed it into google.
Thx
