Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 82 of 82
Thread: Display_ili9341
  1. #76
    Jul 2020
    3
    Sorry, I am not sure what you have or don't have? Maybe post a picture of your display? I believe I still have some of the first ones PJRC released, which would work fine with the different displays. However I am not sure how well the SDCards worked. I believe it was mostly suggested to not use them. But again I am not sure if much of this has changed since then.
    Here is the display I got from PJRC:
  2. #77
    7,473
    You should be able to make the same change to this display like HWGuy did in the thread: https://forum.pjrc.com/threads/28106...ll=1#post72889
    Where he removed the three resistors and replaced them with 0Ohm. Can probably maybe solder bridge it as well.
    Not sure if his other changes are necessary or not. Like the Solder jumper. My guess is that this bypasses the 5v to 3.3v VR on the board. So Vin can go directly to 3.3v instead of the higher voltage. But he then shows external Pull up resistors. Not sure if the external PU resistors he shows would be necessary or not on the SPI pins with this modification.
    Again I have not used the SD Card slots on these displays.
  3. #78
    May 2017
    106
    The pull ups are necessary. Otherwise you will get problems reading SD Card (wich I had).
  4. #79
    Jan 2015
    France
    115
    I'm looking for a convenient way to allow short press and long press on the display. Is there an easy way to do it ?
    Actually my code is this :
        if (ts.touched()) {                             // L'ecran a été touché, faire tourner les vues
          TS_Point p = ts.getPoint();
          if ((p.x >= 0) && (p.x <= 2500)) {
            ScreenChanged = false;
            if (num_screen != 0) {
              num_screen = num_screen - 1;
            else {
              num_screen = 2;
            changeScreen(num_screen);
            unsigned long currentMillis = millis();
            while (millis() < (currentMillis + debounceScreen));
          else if ((p.x >= 2501) && (p.x <= 5000)) {
            num_screen = num_screen + 1;
            if (num_screen > 2) {
              num_screen = 0;
    This code separate the screen in 2 areas, and in regard with the touched area the screen change from left to right, and vice-versa. My goal now is to allow detection of a long press on the screen (let's say 5secondes and more) to enter in a configuration mode.
    Thank you,
    Manu
  5. #80
    12,231
    IIRC the one example set WasTouched in the if(ts.touched()) case. When setting that true the time could be recorded.
    Then in else case look for WasTouched being true and compare the time, and set WasTouched false. If the time between WasTouched and the release is >= 5 seconds then it would be the long press case.
  6. #81
    Jan 2015
    France
    115
    I'm sorry, but it's absolutely unclear :-(
    At least difficult to do (for me)
  7. #82
    Jan 2015
    France
    115
    I finally end with this code. It operate but I think it can be better :
    #define debounceScreen 200    // Millisecondes
    #define longPress 3500
    bool wasTouched = false;
    bool wasReleased = false;
    bool config = false;
    unsigned long pressStart;
    void Screen_Config () {
      do something...
      config = false;
      return;
      if (Serial.available())                           // Mode configuration.
        traiteCommandeFromSerialWithCRC();
      if (TypeAfficheur == 0) {                         // L'afficheur est configuré en mode information
          if (wasTouched == false) {
            pressStart = millis();
            wasTouched = true;
        else {
          if (wasTouched == true) {
            wasTouched = false;
            wasReleased = true;
          if (((millis() - pressStart) >= longPress) && (wasReleased == true)) {
            pressStart = 0;
            config = true;
            Screen_Config();
          else if (wasReleased == true  && (config == false)) {
              else {
                num_screen = 2;
                num_screen = 0;
