KurtE
Senior Member+
Sorry, I know part of this was already talked about in the Teensy LC thread, but thought it maybe deserved it's own thread.
There are times I get tired of using the Arduino IDE, especially since most of the time I am working on libraries and as such need to use a separate editor for those files... So I have been alternating between maybe using Visual Studio or using Eclipse.
I also noticed yesterday they released a new version of the visual micro that supports Arduino 1.6.1
http://www.visualmicro.com/page/Arduino-Visual-Studio-Downloads.aspx
I also noticed that the Teensy page:
http://www.visualmicro.com/page/Teensy-for-Microsoft-Visual-Studio.aspx
Talks about Paul stabilizing the next release which has been released. It also mentioned about editing boards.txt...
So I thought I would give it a try. But even after making the marked edit in boards.txt If I try to compile for Teensy LC (which is in the list), it errors with:
I tried adding a dummy:
Tried also adding some dummy define on it instead of leaving it blank (like -DTeensyLC)
Same error.
So wondering if anyone else has gotten it to work?
Compiling 'ILI9341_Test_ReadPixel' for 'Teensy LC'
arm-none-eabi-g++*:error: {build.flags.optimize}: No such file or directory
arm-none-eabi-gcc*:error: {build.flags.optimize}: No such file or directory
Error compiling
teensyLC.build.flags.optimize=
Same error.
