Results 1 to 8 of 8
Thread: Teensy LC & Audio library issue
    Mar 2015
    7
    On a new Teensy LC, when I compile any of the example sketches that come with the Teensy Audio Library I'm getting this error:
    Using library Audio in folder: /Applications/ArduinoNew.app/Contents/Resources/Java/hardware/teensy/avr/libraries/Audio (1.0.x format)
    /var/folders/tk/rhpm6wds0t3_wm423m_cjxxw0000gn/T//ccSD5jvX.s: Assembler messages:
    /var/folders/tk/rhpm6wds0t3_wm423m_cjxxw0000gn/T//ccSD5jvX.s:339: Error: selected processor does not support Thumb mode `smuad r6,r6,r6'
    Error compiling.
    They all work fine when I switch back to a Teensy 3.1 . I've updated to the latest teensyduino and have tried using both Arduino 1.6.1 and 1.0.6 with no luck Has anyone else had this problem?
    Germany NRW
    5,567
    On LC, the Audiolibrary is not supported.
    Mar 2015
    7
    Interesting--- Is there any documentation anywhere online saying this? I assumed since it had a DAC it would be just as capable with the audio library, or is it just not implemented yet?
    Germany NRW
    5,567
    Well..the easy answer is: Look at your compileroutput:
    "Error: selected processor does not support Thumb mode `smuad r6,r6,r6'"
    The LC is a Cortex M0+ and it does not support the DSP-extensions.
    Even if it had it: the M0 is slower and with only 8K RAM .....
    Boston, MA, USA
    1,106
    Quote Originally Posted by jmzjmzjmz View Post
    List of libraries tested with LC
    https://forum.pjrc.com/threads/27689...C-Beta-Testing
    The Audio library makes extensive use of the Cortex M4 DSP instructions, which the Cortex M0 on LC does not have. The memory requirements for most Audio library sketches also tend to rule out LC.
    Jan 2015
    frisia
    285
    As Frank said, If you get it working, I would expect only some light processing stuff to work.
    If you are willing to invest some time, you might replace the functions in Audio/utility/dspinst.h. Don't know how far you could get.
    This dspinst.h directly calls the assembly functions. If you replace the assembly by a function call to eg __SMUAD, then it should automatically replace this on the cortex m0 with replacements, as defined in arm_math.h
    as an example: replace
    static inline int32_t multiply_16tx16t_add_16bx16b(uint32_t a, uint32_t b)
            int32_t out;
            asm volatile("smuad %0, %1, %2" : "=r" (out) : "r" (a), "r" (b));
            return out;
    by
            return __SMUAD(a, b);
    Edit: quickly tried commenting all assembly instructions (ie no replacement), just to see if it compiles, but immediately ran against all kinds of DMA stuff not defined.
    19,932
    Yeah, it's going to be a big job to get even a small part of the audio library working on Teensy-LC. Most of the audio objects will never run on LC, but a few probably can.
    I will work on this eventually, but I have several other higher priority tasks to do first.
    Jun 2015
    3
    i want to record and play raw data in teensy lc wihout using audio shield.....please suggest me how to go trough using dac and adc pins
