I 'm reading from time to time that with windows there were difficulties to download programs to teensy
This happened to me also when usb-serial was implemented.
I cannot talk about TeensyDuino, as I'm using the command-line loader, but using cli I could make some changes to the code so this does not happen anymore.
It turned out, that after setting the baud rate to 134 , the baud rate was restored to the original (or 115 kBaud in case of TY)
as shown in the two code snippets.
Edit: first snippet is not from original command line loader but imported into my custom version from teensy_reboot.c that I used to augment the functionality of the original command line loader
I put Koromix TY code here as it states the reasons for setting baud rate high again
Well, on my Windows 8.1 system, all problems were gone after I commented the line that restored the baud rate back to the original.
I let it up to Paul and Koromix to assess the validity and generality of this observation and if modifications to TeensyDuino and TY are needed, but for me the change solved the problem.
int send_break(void)
COMMCONFIG port_cfg, port_cfg_134;
DWORD len;
if (port_handle == INVALID_HANDLE_VALUE) return -1;
len = sizeof(COMMCONFIG);
if (!GetCommConfig(port_handle, &port_cfg, &len)) return -1;
memcpy(&port_cfg_134, &port_cfg, sizeof(COMMCONFIG));
port_cfg_134.dcb.BaudRate = 134;
if (!SetCommConfig(port_handle, &port_cfg_134, len)) return -1;
// WMXZ:
// on my windows 8.1 and running T3.1 at 144 Mhz the following line
// was removed to guarantee that HalfKay started (entered pid 478 mode)
// SetCommConfig(port_handle, &port_cfg, len);
// following was removed by Paul
//SetCommBreak(port_handle);
//Sleep(50);
//ClearCommBreak(port_handle);
return 0;
case TY_DEVICE_SERIAL:
r = ty_serial_set_attributes(iface->h, 134, 0);
if (!r) {
/* Don't keep these settings, some systems (such as Linux) may reuse them and
the device will keep rebooting when opened. */
ty_serial_set_attributes(iface->h, 115200, 0);
