serial break command for teensy 3.0
How can you transmit a serial break to one of the serial ports.
The DMX protocol needs a break and a 10 ms pause at the start of every block.
Or do you have to close the channel, reopen it at a lower baudrate, send a zero byte, reopen it at 250000 baud again?
.F
Here's some known-good DMX transmitting code. This was tested with a few different DMX lighting controllers.
The "break" is sent by simply sending a zero at a slower baud rate.
uint8_t buffer[513];
void xmit() {
  digitalWriteFast(12, HIGH);
  Serial1.begin(83333, SERIAL_8N1);
  Serial1.write(0);
  Serial1.flush();
  Serial1.begin(250000, SERIAL_8N2);
  digitalWriteFast(12, LOW);
  // first byte of buffer must be zero
  // to comply with DMX protocol
  Serial1.write(buffer, sizeof(buffer));
  Serial1.flush();
#define RED    0xFF0000
#define GREEN  0x00FF00
#define BLUE   0x0000FF
#define YELLOW 0xFFFF00
#define PINK   0xFF1088
#define ORANGE 0xE05800
#define WHITE  0xFFFFFF
  Serial1.begin(250000);
  pinMode(12, OUTPUT);
  colorWipe(RED);
  colorWipe(GREEN);
  colorWipe(BLUE);
  colorWipe(YELLOW);
  colorWipe(PINK);
  colorWipe(ORANGE);
  colorWipe(WHITE);
void colorWipe(int color)
  for (int i=0; i < 48; i++) {
    buffer[0] = 0;
    buffer[i*3 + 1] = color >> 16;
    buffer[i*3 + 2] = color >> 8;
    buffer[i*3 + 3] = color >> 0;
    buffer[i*3 + 1 + 144] = color >> 16;
    buffer[i*3 + 2 + 144] = color >> 8;
    buffer[i*3 + 3 + 144] = color >> 0;
    buffer[i*3 + 1 + 288] = color >> 16;
    buffer[i*3 + 2 + 288] = color >> 8;
    buffer[i*3 + 3 + 288] = color >> 0;
    buffer[25] = 0x5A;
    xmit();
    buffer[25] = 0xA5;
    xmit();
