Page 2 of 2 FirstFirst 1 2
Results 26 to 28 of 28
Thread: Teensy 3.1 - Correct way to use interrupts on received Serial data
  1. #26
    Germany NRW
    5,429
    Best is to write to SD 512Byte packets (or a multiple of 512) - that's the internal storage block size for SD Cards. Any other size will be slower.
  2. #27
    2,052
    Quote Originally Posted by s_arty View Post
    I would have programmed from scratch using PIT0 from kinetis documentation. (could not find intervaltimer on my TD installation, so I cannot confirm if this is OK for T3.x) Unfortunately the PJRC website examples is full of Teensy2 examples.
  3. #28
    Dec 2018
    9
    Thank you for your suggestions!!!
    When you say, I need to write 512 bytes packets, do you mean sd unit size?
    in my case it's 32 Kbytes
    I'm using SD.h to write file, is there a proper way to write data blocks?
    my example is:
        static Queue  queue1(sizeof(int), 50000); // Instantiate queue
        static const int SD_CLASTER_SIZE = 512;
        while((!queue1.isEmpty()) && (queue1.getCount() > SD_CLASTER_SIZE)){
          queue1.pop(&incoming);
          rawFile.write(incoming);
        rawFile.flush();
