Hi All
As an experiment I have connected a Microchip ENC424J600 (10/10M Ethernet) to a Teensy LC:
http://www.utasker.com/kinetis/TEENSY_LC.html#LAN
Due to the fact that the device hasn't a great deal of code space and its RAM is limited it was not possible to activate all features but I wanted to mainly prove that it could work in parallel with an SD card sharing SPI0 (and switching SPI modes and speeds on the fly). So I set up
- USB-CDC and command line menu
- SD card and FAT
- Ethernet with ICMP and UDP, with DHCP, Netbios and SNTP clients
which allowed the operations to be verified.
In comparison, I recently did something similar for the Teensy 3.1:
http://www.utasker.com/kinetis/TEENSY_3.1.html#LAN
which has lots more Flash and RAM space so allowed a configuration with full features.
The main difference between the K20 on the Teensy 3-1 and KL26 on the Teensy LC with respect to the SPI is that the K20 can automatically share two SPI modes and speeds thanks to its SPI0_CTARx registers. But at the end of the day it is possible to achieve the same functionality with both devices.
Regards
Mark
Ref: https://community.freescale.com/thread/352024
- SD card and FAT
Regards
Mark
