Results 1 to 8 of 8
Thread: Teensy 3.1 - fastest digitalWrite? Is port manipulation still the way to go?
    On the Arduino, for fast I/O you write to the port directly, bypassing the friendly/safe/slow digitalWrite - does this still apply to the Teensy 3.1 / LC?
    I gather Paul's made the PORTn stuff work with Teensys, but is it still fastest?
    h
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    934
    There is also the digitalWriteFast() function as well as port control. See the discussion https://forum.pjrc.com/threads/23431...-using-IO-pins
    Thanks! (That post should be stickied or stuck in the tips thread
    Dec 2014
    310
    My understanding is that you'll always do best with digitalWriteFast. If possible, I believe it compiles to a macro for that port (without you having to do the register legwork and reading). If the pin is variable, it'll compile to a regular digitalWrite.
    I believe there are also other 'fast' functions available, such as digitalReadFast.
    24,452
    Quote Originally Posted by howiemnet View Post
    Yes, there's code which replaces AVR PORTn single-bit logical and / or operations with native digitalWriteFast(), which is the fastest way.
    4,071
    Just to be clear, I believe digitalWriteFast is only fast when the pin number is constant. If it isn't constant, then it falls back to use the general library interface. Unfortunately if you doing abstractions and such, the pin number is often an argument to the constructor, and it becomes non-constant within the abstraction. You should declare pins using the const keyword to make sure the compiler knows they are constant.
    Senior Member Jp3141's Avatar
    486
    Is there any difference between using #define or const for pin definitions ?
    Apr 2013
    London, uk
    934
    h
    Either way, you can easily access port manipulation such as for PORT B: #define RGB_OUT GPIOB_PDOR, and then RGB_OUT = value; where value will be the binary that corresponds to your PORT pins, this could also be given a Hex description for example 0x16 which would be B10000 meaning only the PORT pin at 4 would go High. (counting zero as a value).
