Up to now I did the prototyping for a project with an ARDUINO DUE, but now for size (board dimensions) reasons I want to port the code to the teensy3.0 (and later to teensy3.1)! The code addresses two monochrome 128x64 displays with ssd1306 controller via u8glib. On the ARDUINO DUE with
the diplays are accessed via hardware SPI without any problems. I now tried to port the program to the teensy 3.0, but I only get the display to work with
and software SPI (which is much too slow) but not as hoped with
with hardware SPI! - Is the wiring wrong, or doesn't the u8glib (V1.17) natively support hardware SPI with the teensy3.x?
Thanks for the answers in advance!
For the sake of completeness here is my entire test program for the teensy3.0 with the (working) u8glib initialization for software SPI:
U8GLIB_SSD1306_128X64_2X u8g(6, 7, 8); //U8GLIB_SSD1306_128X64(cs, dc(a0) [, reset])
U8GLIB_SSD1306_128X64_2X u8g2(3, 4, 5);
U8GLIB_SSD1306_128X64 u8g(13, 11, 10, 3, 2);
U8GLIB_SSD1306_128X64 u8g(10, 3, 2);
#include "U8glib.h"
/* Create an instance of the library for the SSD1306 OLD display in SPI mode */
void setup(void)
u8g.setColorIndex(1);
u8g.setFont(u8g_font_fur30);
u8g.setFontPosTop();
int x = -30, a = 1;
void loop(void) {
x += a;
if (x > 100 || x < -30) a = -a;
u8g.firstPage();
do
u8g.drawStr(x, 0, "Hallo");
while(u8g.nextPage());
