Ok, I know how to make voltage dividers, but I need to know the analog input resistance. I see on the pdf for the teensy 3.1 to be either 2 K or 5 K ohms.
I will be measuring a sensor output of near 0 volts to ~ 5volts. This will be related to 0 psi to 3,000 psi. I need to be close since the gauges are in 50 psi steps (I was told).
This is the last part of the product and means nearly done.. No more Saturdays working.
I'm guessing I can put 2 5K's or 2 10K's and sense the center to ground for simplicity.
