Results 1 to 6 of 6
Thread: analogWriteFrequency bug
    Mar 2013
    651
    I seem to have found a small bug in analogWriteFrequency. While working on my eGocart project I managed to do this.
    analogWriteFrequency(22, PWMfrequency);
    analogWriteFrequency(23, PWMfrequency);
    It looks harmless but boy did it kill my afternoon.
    I was trying to set pin 25 High with a switch and a few other variables and it would sometimes go on and off quickly and other times do nothing. After banging my head on my Keyboard for a few hours trying to figure out why my If statement was broken I started disabling huge chunks of code. 900lines later...... I commented out the above code and pin 25 started working......
    It seems that if you write to the same timer twice it borks something, even though pin25 is on a different timer and was not being used for PWM it was pulsing the pin one time instead of holding it High.
    Well I have just enough time left in the day to get drunk and go to bed so later everyone.
    23,956
    Can you please post a complete program which demonstrates the problem?
    There may indeed be a bug in analogWriteFrequency or analogWrite itself. If so, I would really like to investigate and fix it. But I need you to post an actual program that demonstrates the problem.
    Mar 2013
    651
    I will see what I can do, I need to take a break, just spend a few hours troubleshooting pin33......
    I will try to make a small example that has what is needed to reproduce but right now I need Excedrin and Crown.
    The good news is I have a working Precharge and Bypass for my eGocart, and the faults work to Was hoping to run the test motor today but probably be further into the week.
    Mar 2013
    651
    Cant seem to reproduce it with a basic test program.
    I will play around with an older version of the code before I removed the second analogWriteFrequency.
    23,956
    I hope you'll manage to trim it down to something you can post here, which reproduces the problem.
    If there really is a bug in either of those Teensyduino functions, I certainly want to fix it. But I can't even start without knowing how to reproduce the problem.
    Mar 2013
    651
    I have been unable to reproduce it :/
    I even went back to an older version and tried playing with it and could not get it to reproduce.
    Maybe I should have had the Crown before I started yesterday instead of after.....
