Hey everybody!
I'm have a battery powered project that I'm using the Teensy 3.1 in and I'm going to use Duff's Awesome Snooze library to put the Teensy 3.1 into Hibernate when the Battery Management chip's Sleep Pin signals LOW, and then wake from Hibernate when the Sleep Pin signals High.
From what I'm seeing this should be pretty easy to do.
I also want to wake from Hibernate via 2 additional sources also and I'm not sure if that's possible so I'm hoping @Duff can chime in with some advice.
Here are the 2 additional wake sources I would like to setup.
1. Wake via timer set for 24 hours. So Wake from Hibernate every 24 hours.
2. Wake from a Cap Touch pin when touched. I plan on using Cap Touch buttons for LCD screen navigation anyways.
Is it possible to use all 3 of these at the same time without problems?
