Results 1 to 3 of 3
Thread: Teensy Loader won't open 256k Hex File
    I'm trying to load a .hex file that completely fills the Teensy's flash, and Teensy Loader gives an error "ihex: parse error line 16388". If I delete one byte from the .hex it loads fine. I'm using Teensy Loader 1.23
    I'm trying to put a CRC at the end of flash in case you're wondering why I need to fill the whole flash.
    Here are two sample files - Blink Example padded with 0xff's up to the end of flash and minus one byte.
    https://db.tt/jX8G9aqv
    https://db.tt/uKFQr79Q
    Administrator Paul's Avatar
    Oct 2012
    390
    I put a fix for this into 1.24-beta3.
    Please let me know if it works for you?
    Sorry for the long delay in getting back. The new loader does work with a 256k hex file. Can you update the standalone Teensy Loader to the latest version at some point?
    https://www.pjrc.com/teensy/loader.html
